Toymods » Tech & Conversions » TVIS on the 4age
carsanactra
melbourne
TVIS on the 4age Thu, 15 April 2004 14:50 Go to next message
the TVIS system is a set of butterfly valves that close off the intake valve ports below 4500 rpm. is this good or bad?
would it be better to have this port closed constantly, open constantly, or leave it the way it is?
ae95
Re: TVIS on the 4age Thu, 15 April 2004 20:24 Go to previous messageGo to next message
Depends on the cams you have pretty much. If your engine is fairly stock - eg. exhaust, extractors, filter you'd be better off leaving it.
Rex_Kelway
Re: TVIS on the 4age Fri, 16 April 2004 13:00 Go to previous messageGo to next message
TVIS is there for a reason, it increases the air speed into the cylinders at low rpm.
If your motor is stock leave it, as i said the Toyota engineers are not stupid, they develloped it for a reason.
Someone (cant remember where i saw it) did a test between your three modes of operation (open, closed & normal). The TVIS enabled motor made a considerably favourable power curve.
pepsicola
Re: TVIS on the 4age Fri, 16 April 2004 15:53 Go to previous messageGo to next message
where's this valve located anyway?
FKN16V
NSW, East Coast
Re: TVIS on the 4age Fri, 16 April 2004 16:00 Go to previous messageGo to next message
pepsicola wrote on Sat, 17 April 2004 01:53
Its not a valve so to speak, more like 4 little throttle bodies(about the size of a 20cent piece each) between the inlet manifold and the head. The butterflies stay closed to increase air velosity at low rpm to promote torque, when rpm gets high enough (around 4500rpm) butterflies open fully and then all hell breaks loose?
pepsicola
Re: TVIS on the 4age Sat, 17 April 2004 04:10 Go to previous messageGo to next message
so where are these located inside the manifold?
FKN16V
NSW, East Coast
Re: TVIS on the 4age Sat, 17 April 2004 05:27 Go to previous message
pepsicola wrote on Sat, 17 April 2004 14:10
Where the inlet manifold bolts to the head, theres a small 1/2 inch plate between the head and the inlet manifold. there in there, they are activated buy a solenoid and a vacumm tank (green round cylinder) just behind the water pump.
Previous Topic:Urgent: Gearbox Identification ?
Next Topic:Standard cams?
Current Time: Tue Oct 20 04:54:15 UTC 2026
Total time taken to generate the page: 0.0046300888061523 seconds
