Toymods » Tech & Conversions » MA61 Clutch Slave different to SA63?
wilbo666
MA61 Clutch Slave different to SA63? Fri, 16 April 2004 00:47 Go to next message
Hey guys, do toyota have different clutch slaves for different models (and even the same models?).
My clutch fork will not work with the SA63 slave (MA61 Fork and bellhousing)
http://everest.fit.qut.edu.au/~n4150414/Dsc00180.jpg
I'm guessing that there will be an MA61 slave that will solve my problems (btw why the hell would toyota make them different!)? I'll goto repco this arvo and see if there is different part numbers...
bbaacchhyy
Re: MA61 Clutch Slave different to SA63? Fri, 16 April 2004 01:05 Go to previous messageGo to next message
I have had 2 different slave cylinders and they are the same.
Typically it is the actual clutch fork that is different. You may have to change that (a shit of a job), or given that everything is already installed, make up a spacer for the slave cyl to sit out further from the bellhousing.
This may cause other issues with pedal travel (need to maybe go up a size in the Clutch M/Cyl to get the travel req'd.
So in short, the clutch slave cyl's that I have always seen are the same IME.
Michael B
Re: MA61 Clutch Slave different to SA63? Fri, 16 April 2004 02:01 Go to previous messageGo to next message
Ditto that. As discussed last night, I have seen different clutch forks but never different slave cylinders. This is comparing the RA60, RA65, MA61 and JZA80 setups; all slave cylinders are identical.
wilbo666
Re: MA61 Clutch Slave different to SA63? Fri, 16 April 2004 02:34 Go to previous messageGo to next message
How the fuck can that work Confused , this is the setup (fork, bellhousing, throwout bearing, clutch and pressure plate, in short EVERYTHING) that came out of blakes (aka v8_ma61) MA61.....
I'll have to go and check his slave cyl out when he gets back...
Norbs, the slaves that come on the RA65 were different weren't they (because they sit on the drivers side of the bellhousing they were mirrored?)
bbaacchhyy
Re: MA61 Clutch Slave different to SA63? Fri, 16 April 2004 02:45 Go to previous messageGo to next message
wilbo666 wrote on Fri, 16 April 2004 12:34
Bellhousing is different ?
wilbo666
Re: MA61 Clutch Slave different to SA63? Fri, 16 April 2004 03:23 Go to previous messageGo to next message
Nope stock MA61 5M-E -> W58 Bellhousing, Fork, Clutch, Pressure Plate, Throwout Bearing (the only thing I don't have is the slave cyl!)
bbaacchhyy
Re: MA61 Clutch Slave different to SA63? Fri, 16 April 2004 03:27 Go to previous messageGo to next message
Hmmmm. Maybe it seems like something got mixed up ?????
Re: MA61 Clutch Slave different to SA63? Fri, 16 April 2004 04:04 Go to previous messageGo to next message
Are you sure you put the clutch fork on correctly, ie it's properly attached to the throwout bearing? I know it sounds dumb, but I put a clutch plate in backwards once so anything's possible. Laughing
Re: MA61 Clutch Slave different to SA63? Fri, 16 April 2004 04:29 Go to previous messageGo to next message
wilbo clipped the fork onto the thro-out bearing - they only fit one way i think and thus should position the fork arm correctly.
am pretty sure it was seated on the pivot ball - i think you can lift back the boot to check that one at least
i'm sure wilbo doesn't feel like re-installing that gearbox (me neither) Mad Confused
unless we got a big ford clutch arm from Blake by mistake?
[Updated on: Fri, 16 April 2004 04:30]
wilbo666
Re: MA61 Clutch Slave different to SA63? Fri, 16 April 2004 07:02 Go to previous messageGo to next message
God, I am an idiot Embarassed so embarrassed Embarassed so stupid Embarassed Embarassed Embarassed
All I needed to do is learn how to install it correctly (stupid pivot hole Confused, no really I'm just an idiot)
Thanks for the help anyway guys.
Re: MA61 Clutch Slave different to SA63? Fri, 16 April 2004 07:09 Go to previous messageGo to next message
ummm ... willbo? .. i hope ya didn't remove the entire gearbox to fix it?
you just had to lift that boot out of the way??? Embarassed
so maybe i should have bought the haynes manual over?
O/T btw - are you collecting the tools today? otherwise, i've got to look at a car at canon hill so i'll bring them with me if needed in the taxi.
W/O/T - missed out on a 4AGE AE82 Seca - waz only $2.8k Confused
wilbo666
Re: MA61 Clutch Slave different to SA63? Fri, 16 April 2004 07:55 Go to previous message
No no, didn't even touch the fork or gearbox (wasn't seating the slave in the pivot hole correctly)
Umm yeah I'll phone you in 2 secs!
Previous Topic:Engine
Next Topic:who knows anything about nitrous jets ??
Current Time: Thu Oct 8 04:32:26 UTC 2026
Total time taken to generate the page: 0.093159914016724 seconds
