Toymods » Tech & Conversions » 1uzfe in a corolla
esv8
kyabram,victoria
1uzfe in a corolla Fri, 16 April 2004 05:53 Go to next message
Hello, i am an absolute corolla nut from victoria and was just curious as to weather or not it is possible to get a 1uzfe engineered for rego in any of the rear wheel drive corollas. Particularly a ke20, i know it will be a tight fit but i want to do this conversion, and would like it registered. If not it will just be for burnout comps. Any input would be appreciated.
sideshow
Re: 1uzfe in a corolla Fri, 16 April 2004 06:19 Go to previous messageGo to next message
not to sure on vic rules but 3 times the weight of car for n/a engines will give u max engine capacity so i gather 4 lts is bit too much
Bill Sherwood
Brisbane / Gold Coast
Re: 1uzfe in a corolla Fri, 16 April 2004 07:14 Go to previous messageGo to next message
There's a guy in Melbourne that's put one into an AE-86 and is about to get it registered.
I'm putting one into a KE-55S, but it's a rally car and the front of the engine will be nearly level with the firewall. Smile
Super Jamie
On Probation
North East NSW
Re: 1uzfe in a corolla Fri, 16 April 2004 08:00 Go to previous messageGo to next message
you won't get that ke20 registered as a modified vehicle. rewind about 15 years and it was possible. who remembers that guy who got his v8 gemini in all the magazines, but the law changed about 4 months before he finished his clean streeter project. they wouldn't let him register it, even tho the build was years old
read some RTA or vic roads documents, you may be able to register the car as an ICV, but it will have to be compliant with all current ADRs. airbags, side intrusion, crumple zones, etc. the amount of money you'd spend on a ke20 getting it to that stage, fuck! i'm pretty sure i'm the biggest KE corolla advocate in the world and not even i would do that, it wouldnt even be a ke20 at the end of it anyway, there's no point
one other thing you might be able to do is shorten and narrow an HQ chassis and drop the ke20 shell onto that, you'd just have to register your corolla as a 1972 holden utility
if you don't mind just having a v8 racecar though, do that. there's a ke17 drag car up at willowbank (george wegener, read the latest drag racing aust magazine). and there's a ke20 at grafton hillclimbs with a 327 in it. i've taken the measurements, you can fit a 302 windsor in a ke30 without moving the firewall back, not too sure about the strut tops
Super Jamie
On Probation
North East NSW
Re: 1uzfe in a corolla Fri, 16 April 2004 08:02 Go to previous messageGo to next message
Super Jamie wrote on Fri, 16 April 2004 18:00
ps: i dont think you could do this either, there's a limit to how far you can narrow track and shorten a wheelbase
onejayzed
Re: 1uzfe in a corolla Fri, 16 April 2004 08:06 Go to previous messageGo to next message
whether you can rego it or not, i have doubts that it will fit physically.
the 1UZFE is approx 700 high, 700 wide and 700 deep. run a tape measure over your engine bay and i don't think it will fit.
if you're dead set on a V8, what about the 4MVE ? it's an OHV 3.4L, all alloy hemi-style V8 used by toyota for something like 20 years in Japan, and all 5MG parts are compatible, including the pistons Very Happy EKW have them in stock for around $2200 i think. these 'should' fit, but again, a tape measure will remove all doubt. use a celica box and you're away.
otherwise, i can pretty much guarantee that a 3.9L rover V8 and a celica box will 'slot' in between the strut towers, but mounts / sumps etc may be a prob.
and if you get it rego'd, then send me a picture of your car. that way i don't get embarrassed when i line you up at the lights. Laughing
onejayzed
Re: 1uzfe in a corolla Fri, 16 April 2004 08:08 Go to previous messageGo to next message
Super Jamie wrote on Fri, 16 April 2004 18:02
once you cut and shut a chassis, it is no longer a rebodied vehicle. it is now an ICV. and you DONT want that.
esv8
kyabram,victoria
Re: 1uzfe in a corolla Tue, 20 April 2004 02:05 Go to previous messageGo to next message
i have seen a guy in melbourne with a 289 windsor in a ke20 (or a model close to that, he had the plates TWO-89), at the easternats last year and i heard he had it registered as a 289 but i'm not 100% sure. this was the only reason i was curious.
Would it be possible to get a quad cam rego'd in a ta22 celica then? i want something small with one of these engines in it so i'm gunna be persistant till i get it.
sideshow
Re: 1uzfe in a corolla Tue, 20 April 2004 02:18 Go to previous messageGo to next message
well in sydney its 3 times the weight
so 4000 divided by 3 is 1333 kgs
so this means in sydney the car has to be over 1.3 kgs
unless it has a chassis
its only afew phone calls to afew engineers
why not just ask them
the rules change all the time so half of us cant keep up
if u r persistant it means u have alot to spend
anything u put it in is goin to be a big job
so just call engineer and see what they say
Re: 1uzfe in a corolla Tue, 20 April 2004 03:42 Go to previous messageGo to next message
unless the cr weighs over.. is it 1000kg? and then it's 5x weight
so find a car that is 1001kg from factory, and thats the lightest car the 1UZ will be ok in in NSW..
and from memory the KE10 engine bay is about 600x600x500 (one of those 600's might be 500 or 700 tho Wink ) so i very much doubt it will physically fit in a KE20, which is only slightly longer...
mmmm 200mm speedbubble Very Happy LOL
CYa, Stewart
Re: 1uzfe in a corolla Tue, 20 April 2004 03:45 Go to previous messageGo to next message
esv8 wrote on Tue, 20 April 2004 12:05
and what year was it first registered with that motor??? i'd guess a few at least....
DJ345
eastern suburbs, Melb
Re: 1uzfe in a corolla Tue, 20 April 2004 06:04 Go to previous messageGo to next message
A friend was going to put one in a ke20 for a customer and they found it would just fit, so they looked at a genIII out of the latest commodores and I looks to be an easier fit, Dont know how far they have got yet.
onejayzed
Re: 1uzfe in a corolla Tue, 20 April 2004 08:56 Go to previous messageGo to next message
they're a big engine, and the VQ45DE is wider again (nissan version).
seriously, a 289 would be an orse little drag car, so would a s/c 4MVE...
V8_MA61
Re: 1uzfe in a corolla Tue, 20 April 2004 09:26 Go to previous messageGo to next message
302 windsor is the same as a 289....itd fit in nice and easy Cool
Re: 1uzfe in a corolla Tue, 20 April 2004 09:54 Go to previous message
By the way it's a 4VE, and they're not much narrower than a 1UZ.
I have some pics of a 4V in an RT104 and it was a bit of a squeeze.....it needed a rack and pinion conversion to fit.
Previous Topic:3SFE wiring diagrams
Next Topic:Door trim removal on Camry Sv21
Current Time: Fri Oct 23 10:04:07 UTC 2026
Total time taken to generate the page: 0.0056259632110596 seconds
