Toymods » Tech & Conversions » Single Turbo 1g-gte
punkdefender
Dandenong/VIC
Single Turbo 1g-gte Fri, 16 April 2004 08:59 Go to next message
Hi all,
Would a t04e with 0.48 exhaust housing suit a 1g-gte?
Cheers..
old_mr2
Re: Single Turbo 1g-gte Fri, 16 April 2004 10:25 Go to previous messageGo to next message
this is parts for sale mate. you want the Tech and Conversions section
CrAiGzEE
south of the big smoke
Re: Single Turbo 1g-gte Fri, 16 April 2004 13:20 Go to previous messageGo to next message
personally id go a bit bigger .68 or so
punkdefender
Dandenong/VIC
Re: Single Turbo 1g-gte Wed, 21 April 2004 08:27 Go to previous messageGo to next message
Its actually a 0.48 T3 exhaust housing..
It already had 0.63 housing which aparently was too laggy
Cheers..
Chris Davey
sunny coast, qld
Re: Single Turbo 1g-gte Wed, 21 April 2004 08:37 Go to previous messageGo to next message
i had a gz20 soarer but just standard turbos. IMO i would think the .48 would be more suitable. My 1g really seemed quite laggy so I would try to stick with the smaller A/R when going to something the size of a t04.
CrAiGzEE
Re: Single Turbo 1g-gte Wed, 21 April 2004 13:04 Go to previous messageGo to next message
what are the size of the standard turbos?
Bugman
Re: Single Turbo 1g-gte Thu, 22 April 2004 08:34 Go to previous messageGo to next message
I'd go with the .68
thats my plan to go with a gt30 the 6-700 hp one.. .68
Fattony
Re: Single Turbo 1g-gte Fri, 23 April 2004 07:32 Go to previous message
I would have to concur on the .63. The .48 will be to small to be able to be efficient up in the high boost range 20psi + and will more than most likely run out of puff before you run out of revs. Belive it or not there is a actual science to turbocharger housing sizing. To small a housing you will cause back pressure in the manifold and hamepering performance and turbo spool up, to big a housing and you will cause a pressure drop in the zorst housing and the same result will occur. I word of adivice, ask around to the ppl that have used this this type of turbo on 2l motors and see what they would say about the housings they used and the way the car came on boost and went.
Previous Topic:Boost Hard
Next Topic:Compression Ratio . 20v head on a 4agze ??
Current Time: Mon Oct 26 20:19:56 UTC 2026
Total time taken to generate the page: 0.0095269680023193 seconds
