Toymods » Tech & Conversions » Spark plug sleeves
oldskoolrolla
Ashmore, QLD
Spark plug sleeves Sat, 17 April 2004 09:00 Go to next message
My 4K motor is leaking oil from the spark plug sleeves Mad I am guessing they need replacing. Are these sleeves readily available from a Toyota Spare Parts dept or do you think I will have to replace the rubber o-ring and retain the original sleeve body? Any ideas on costing for new ones?
Re: Spark plug sleeves Sat, 17 April 2004 10:49 Go to previous messageGo to next message
is it leaking from around the top or around the bottom.
if the bottom is damaged form doing up the plugs too tight (or just repeatedly), you can buy them new from toyota as parts for a 7KE motor (they are the same).
for the rubber, i prefer to use appropriately sized O-rings with a very slight smear of silicon. seals much better.
check that you have not blocked off the rocker cover vents (and PCV) as high crankcase pressure often results in oil being blown out the spark plug tube seals...
if it's just weeping out, try using o-rings...
oldskoolrolla
Ashmore, QLD
Re: Spark plug sleeves Sun, 18 April 2004 03:27 Go to previous message
thanks stewart,
the body itself isnt damaged in any way, so I may just replace the o-rings and take your advice and put a touch of silicone to seal. Its actually leaking out the the top of the sleeve, so I think just the rubber ring needs replacing
ta,
dan 'o'
Previous Topic:1gge conversions
Next Topic:Gt 4 boost problem
Current Time: Sat Oct 24 01:02:55 UTC 2026
Total time taken to generate the page: 0.003756046295166 seconds
