Toymods » Tech & Conversions » ma70 engine warning light! Grrr
V8_MA61
ma70 engine warning light! Grrr Sat, 17 April 2004 10:53 Go to next message
I was on my way home from dubbo today, and overtaking someone - probbaly getting up to about 140-150km, and as i passed and slowed down, my engine light came on. I pulled over and turned the car off. Waited a few seconds and then i started it...light was off and i started driving again.
Probably about 1/2 hr later i did the same at about 130km, and the light came on again...so i repeated the same process.
And once again going up a rise, doing about 110, the light came on.
I had no more re-occurances of it during the rest of the day, but i also didnt push the car.
it was in "normal" mode in the auto, and is also using about 8L / 100km of fuel on the highway. I have suspicions the O2 sensor is gone, but if somsone can go further please help!
Blake
Re: ma70 engine warning light! Grrr Sat, 17 April 2004 10:56 Go to previous messageGo to next message
what code do you get from the diagnosis port?
more...
from <http://www.off-road.com/toyota/tech/codes/> and probably oin teh forum somewhere (tech docs?)
...ump the two terminals in this connector with the ignition switch in the "ON" position and the engine off. Later models, '87 and newer use a multiple terminal "DIAGNOSTIC" connector which is a small, rectangular-shaped grey "box", usually located near the right fender in the enigne compartment. To get codes out of this type of connector, jump the "TE1" and "E1" teminals. Finding these terminals is easy as the inside cover of the diagnostic connector contains a schematic of the connector pinouts...
...The trouble codes will appear as flashes of the check engine lamp. Be sure the ignition key is on, the engine off, and your foot off of the accelerator when reading the codes. Two different codes may appear: One-digit and two digit. One digit codes have an approximate 4.5 second delay between flashes with the check engine light illuminating for about a half of a second. Mulitiple codes have a 2.5 second delay between them...
[Updated on: Sat, 17 April 2004 11:02]
V8_MA61
Re: ma70 engine warning light! Grrr Sat, 17 April 2004 11:05 Go to previous messageGo to next message
what exactly do you mean the diagnosis port?
Re: ma70 engine warning light! Grrr Sat, 17 April 2004 11:33 Go to previous messageGo to next message
shoud be near the fuse box?
this is the pic from the site above...
http://www.off-road.com/4x4web/toyota/tech/codes/images/diag1.jpg
V8_MA61
Re: ma70 engine warning light! Grrr Sat, 17 April 2004 11:36 Go to previous messageGo to next message
ill have to look into that. Just seems weird it didnt happen on the way down and i gave it a hammering to keep up with norbie. however i did have it in "power" mode on the way down...so im wondering if that has come into play at all?
[Updated on: Sat, 17 April 2004 11:36]
Re: ma70 engine warning light! Grrr Sat, 17 April 2004 11:41 Go to previous messageGo to next message
possibly - tho too many options until you get a code...
was the engine miss-behaving at all when you got the light? doesnt he power/econ mode mostly affect gearbox behavior? or does it also try to run the motor cruise/closed-loop more often?
V8_MA61
Re: ma70 engine warning light! Grrr Sat, 17 April 2004 11:44 Go to previous messageGo to next message
apart from excessive fuel consumption it was perfect. All gauges perfect, no missing, no rattles. Quiet as a mouse!
Power/norm i thought is the controlled by the ecu? I may be wrong...yeah it does control the box's changing times/rpm etc...its a weird one!
Re: ma70 engine warning light! Grrr Sat, 17 April 2004 11:54 Go to previous messageGo to next message
oh yeah... i was thinking about the overdrive switch... my bad..
the switch is probably used by both ECUs - on a contemporary car, the power/econ mode affect shift points, overdrive lockup as well as engine behaviour.
Allan
Re: ma70 engine warning light! Grrr Sat, 17 April 2004 15:18 Go to previous messageGo to next message
I would say the ecu is chucking a fix because it cant get the target cruise mixtures after X ammount of time as full enrichment/enleanment so you get a free orange light!
Replace your O2 sensor might be an idea!
Allan
Re: ma70 engine warning light! Grrr Mon, 19 April 2004 00:17 Go to previous messageGo to next message
Like I told you already, your O2 sensor is probably shagged. Test and replace if necessary.
RobST162
Re: ma70 engine warning light! Grrr Mon, 19 April 2004 01:13 Go to previous messageGo to next message
hey V8... Interesting one this.
My 162 does EXACTLY the same thing. Drive it for a long as you like all week and nary a light to grace my dash, BUT stick the cruise on for say, oh, half and hour, and my friendly little engine light turns on. Even did it on the way to penrith this week.
The old girl purrs like a kitten, doesn't use any more fuel etc etc, yet we have a light.
NOW I did notice that it came on quicker when the car was "lower" on oil than when I had it topped right up. (I had lots of time to test my theories while I was busy driving all around NSW, VIC and TAS)
Now I don't want my ECU to be stuffed, as I have a Jap one methinks so I will be very interested in what you find out...
Rob Smile
V8_MA61
Re: ma70 engine warning light! Grrr Mon, 19 April 2004 07:49 Go to previous messageGo to next message
Norbie wrote on Mon, 19 April 2004 10:17
What do i need to be able to test it?
[Updated on: Mon, 19 April 2004 08:01]
HighRolla
Re: ma70 engine warning light! Grrr Mon, 19 April 2004 08:07 Go to previous messageGo to next message
The ECU should capture the code and have it stored right? You have to short the diagnostic terminal (when car is off). Then turn the car's ignition to "on". The check engine light should flash in a certain pattern to reflect what code it has stored. You will have to look up your manual to check where diagnostic terminal is. Just grab a bit of wire about 100mm long and bridge the terminal. It's possible there is more than 1 code stored.
Oxygen sensor will be a certain code.
Good luck.
V8_MA61
Re: ma70 engine warning light! Grrr Mon, 19 April 2004 08:15 Go to previous message
thanks charles and hirolla, ill look at it sometime this week.
Previous Topic:1G GTE diff and cooler upgrades???
Next Topic:MR2 Snorkel.. how/where/price
Current Time: Fri Oct 23 14:49:38 UTC 2026
Total time taken to generate the page: 0.0048918724060059 seconds
