Toymods » Tech & Conversions » digital dash help
jackel
digital dash help Sat, 17 April 2004 15:41 Go to next message
hey just got a digital dash installed in my corona (i was told it came off a st141 corona with a 2s-c same as mine)and it's all good except for the fuel indicator, there is no bar at all that shows up so i don't have a clue how much fuel i have.
The temperature ones works but on my old dash it was always on a 1/4 and on this one it sits on half. So i don't know if i need to ajust anything or if the fuel indicator is working but it's higher then the "full" mark?
need help don't wanna run out of fuel Razz
[Updated on: Sat, 17 April 2004 15:42]
Grega
melbourne.victoria.austra...
Re: digital dash help Sat, 17 April 2004 21:02 Go to previous messageGo to next message
possibly the fuel sender in the olympic edition st141 from way back then was different?
[Updated on: Sat, 17 April 2004 21:02]
FKN16V
NSW, East Coast
Re: digital dash help Sun, 18 April 2004 00:57 Go to previous messageGo to next message
I have the same trouble with my ae86, your digi dash wont read the signal from your current fuel sendor, get an auto electrician to sort it out for you, or see if you can get the fuel sendor from the donor car?
Steve
Camry_omega
Campbelltown, NSW, Austra...
Re: digital dash help Sun, 18 April 2004 02:42 Go to previous messageGo to next message
Work out how much range you get from a tank of fuel then use the odo to work out how much fuel you should have left?
._T_.
Re: digital dash help Sun, 18 April 2004 02:49 Go to previous messageGo to next message
typical problem with the later digital dash units (ie ae90+ corola) etc was the sender is very different to the normal one - not sure why/what is different - you may have to source the correct sender to suit the dash
FKN16V
NSW, East Coast
Re: digital dash help Sun, 18 April 2004 10:48 Go to previous messageGo to next message
._T_. wrote on Sun, 18 April 2004 12:49
I thought there might be some sort of signal converter but it seems apparent that the original sender is a much easier/cheaper option.
CLG
Perth, Western Australia
Re: digital dash help Sun, 18 April 2004 10:59 Go to previous messageGo to next message
I actually have a sender unit from a digi dashed Corona available if you need it?
Clint
FKN16V
NSW, East Coast
Re: digital dash help Sun, 18 April 2004 11:12 Go to previous messageGo to next message
CLG wrote on Sun, 18 April 2004 20:59
Clint
Do you know if it would work with a ae86 digi dash.
How much you chasing.
Steve
jackel
Re: digital dash help Sun, 18 April 2004 13:19 Go to previous messageGo to next message
i pulled it apart today looking if anything was dissconnected but could see anything, it looks mad with the cover is off and you can see all the circuits i might keep it like that Very Happy
also sometimes when i fiddle with it when i connect it all the way in it clicks then when i put my headtights on the whole dash turns off Confused but that doesn't matter cause i only put it half way in and it works fine.
how much you looking at for the fuel sender cause i would need it but i don't wanna pay alot for it since i got the dash for $60 Very Happy
ChuckLandwehr
Re: digital dash help Mon, 19 April 2004 12:21 Go to previous messageGo to next message
To get an "accurate" temp reading, you will need the temp sender unit from the donor cars engine.
Toyota have always played with these little jiggers. The First Camry's exported to UAE in the desert, had the same sender as the Aussie Camry's. The Locals over there were concerned that the guage wasn't reading high enough for the warmer climate! Toyota's fix --- change the sender unit, so that the needle sat higher!
regards Chuck.
jackel
Re: digital dash help Tue, 20 April 2004 14:56 Go to previous message
http://images.cardomain.com/member_images/1/web/553000-553999/553816_18_full.jpg
this should explain but if it's the fuel sender then thats what i need Smile
took that with my phone, not bad hey Very Happy
[Updated on: Tue, 20 April 2004 14:58]
Previous Topic:4AGE ignitor difference?
Next Topic:injector question...
Current Time: Mon Oct 26 14:19:14 UTC 2026
Total time taken to generate the page: 0.094472885131836 seconds
