Toymods » Tech & Conversions » GA61 and 2nd gen 1G-GTE wiring diagrams?
HyDrA
Adelaide, SA
icon9.gif  GA61 and 2nd gen 1G-GTE wiring diagrams? Sat, 17 April 2004 23:16 Go to next message
Hi all,
I'm after wiring diagrams for the GA61 and 1G-GTE... It seems the wiring diagrams on the toymods site are possibly for a chaser or something (the colours are all wrong).
One major difference is that the 24pin plug on the GA61 is a part of the cars wiring loom, not the engine loom, while the 1g-gte's 24pin plug is part of the engine loom.
Any suggestions?
Grega
melbourne.victoria.austra...
Re: GA61 and 2nd gen 1G-GTE wiring diagrams? Sat, 17 April 2004 23:34 Go to previous messageGo to next message
speak with sixworks (grant) from these forums. he has all this information.
Re: GA61 and 2nd gen 1G-GTE wiring diagrams? Sat, 17 April 2004 23:46 Go to previous messageGo to next message
HyDrA wrote on Sun, 18 April 2004 07:16
Hi all,
Any suggestions?
The colours change from year to year or when the Toyota engineers got bored, what you need to look for more is the pinouts themselves.
The techdocs do indeed have the Gen2 diagrams, just have to look around.
ddeane
PNG
Re: GA61 and 2nd gen 1G-GTE wiring diagrams? Sun, 18 April 2004 00:17 Go to previous messageGo to next message
Gidday
Do a bit of a search as most of this has been covered before. I did have a quick look but could not find it, and I put a lot of the stuff there. You are right the diagrams in the gallery are for gen3. This should not be a real problem as the are only several main defferences.
1. The pins outs - the gen 3 had different number of pins on the plugs and therefore different pin outs. I have posted the gen2 pin outs in the gallery. Also note that I have posted the pinouts for the other two plugs in the loom located near the computer. One is for the dash and the other for the rest of the car electonics. Again look in the gallery
2. The Gen 3 does not use an ignition ballast resister. If you have the original loom this will not be a problem as its location will be obvious - its the rectagular box near the coil and ignitor. If you still have problems I can scan that page of the manual.
I have never seen a full wiring diagram for a gen 1/2, just the bits spread through my engine manual.
IF you are still having problems give me a ring on 0413190752.
Craig
Re: GA61 and 2nd gen 1G-GTE wiring diagrams? Sun, 18 April 2004 00:30 Go to previous messageGo to next message
There are indeed some Gen2 pinouts in the techdocs, no wiring diagrams though. Providing you have the factory loom, there aren't *too* many external connections which is what I'm counting on. I'll e-mail you the stuff I have if you'd like, just fire me an address you want them to go to.
Grega
Re: GA61 and 2nd gen 1G-GTE wiring diagrams? Sun, 18 April 2004 06:10 Go to previous messageGo to next message
i did manage to find this :
http://members.optushome.com.au/mkhala/red_celica/ 1G-GTE_info/1g_gte_ecu_wiring.pdf
justcallmefrank i've sent u a PM.
Grega
Re: GA61 and 2nd gen 1G-GTE wiring diagrams? Sun, 18 April 2004 06:11 Go to previous message
oh and more goodness here :
http://www.1jz-gte.us/Images/1ggte/1g-gte.pdf
(but its in japanese, not too hard to translate some of it)
Previous Topic:1G where 18R/22R used to be...
Next Topic:4age rod specs
Current Time: Fri Oct 23 23:06:27 UTC 2026
Total time taken to generate the page: 0.0053420066833496 seconds
