Toymods » Tech & Conversions » Sprinter Wiring Diagram (dash/tacho)
Les
Sprinter Wiring Diagram (dash/tacho) Sun, 18 April 2004 04:57 Go to next message
before I rip the dash open and reconnect my original tachometer... can someone give me some pointers ? i.e. which wires from the ECU need to be connected to the back of the dash etc .... OR even if this can be done ? i.e. digital signal from the ECU to the old dash ... ?
FYI
I removed the old monster tacho and there were 3 wires from the Microtech ECU
a black/yellow (ground)
blue/white (signal)
white/red (power)
[Updated on: Sun, 18 April 2004 07:53]
Les
.. Sun, 18 April 2004 07:39 Go to previous messageGo to next message
help ?
[Updated on: Sun, 18 April 2004 07:54]
Les
Re: .. Mon, 19 April 2004 12:45 Go to previous messageGo to next message
bump
Henn
Rosanna, Melb
Re: Sprinter Wiring Diagram (dash/tacho) Tue, 20 April 2004 14:34 Go to previous messageGo to next message
If your car was origianly distributored then you will have to screw around a bit to get your dash tacho to work. They work on the voltage spike from your coil. AFAIK, the microtech will be outputting a 5V square wave for the tacho.
So plugging your microtech tacho output into your stock sprinter tach wont work. I tried this and had my tacho going with my indicators.
There is a reasonably simple fix, so if this sounds like your situation then let me know and I'll send you a circuit diagram.
Hen
John S
Re: Sprinter Wiring Diagram (dash/tacho) Tue, 20 April 2004 21:53 Go to previous messageGo to next message
If your talking about the circuit that uses diodes and a resistor it doesn't last too long; gets too hot and fries the components. My mates auto electrician tried it twice before using a Sixworks Tacho Booster. Never had one bit of trouble after that.
JDM hachi
was adelaide now newcastle
Re: Sprinter Wiring Diagram (dash/tacho) Tue, 20 April 2004 23:46 Go to previous message
or a vr4 galant tacho adaptor, wire the inputs from the neg of each coil, out put to tacho, easy, works with both digital and analogue tacho's.
matty.
Previous Topic:Fixing stone chips and scratches
Next Topic:4AGE ignitor difference?
Current Time: Fri Nov 20 18:53:22 UTC 2026
Total time taken to generate the page: 0.038791179656982 seconds
