Toymods » Tech & Conversions » clunky diff which part is it????
ta2272
icon5.gif  clunky diff which part is it???? Sun, 18 April 2004 09:53 Go to next message
i have a ta22 with the stock diff there is a noise when going really slow just a little clunking like evere meter u go there is a clunk, the faster you go it becomes unhearable.
If possible i dont want to replace the hwole diff just the center, but how do i find what is makeing the clunking noise and which is bugger thanks.
jason
hemi twofifteen turbo
Re: clunky diff which part is it???? Sun, 18 April 2004 10:19 Go to previous messageGo to next message
is it a double tick? like a tic-tic....tic-tic....
it could be a wheel bearing, or axle..
or even a loose rear drum shoe, wobbling inside the drum..
did it happened after any diff strees or just came in from nothing?
You can try jacking the car up in the air, putting it in neutral and spinning the rear wheels manually to pin point the location..
If the noise becomes bad going around a corner, ie, making one wheel spin faster than the other, then it's the spider gears.
If the noise is unchanged then it's probably the crown/pinion.
Although it could be wheel bearing, wheel, axle, etc etc...
Oh and check your wheels are all on tight!! I had a diff clunk
that was "getting worse and worse", when it was apparently
'about to blow' lucky I was on my way down an on ramp to the fwy, and got that gut feeling "check car, you are going to die" feeling, and yep back wheel had 1 nut left on it.
hope this helps!
ta2272
Re: clunky diff which part is it???? Sun, 18 April 2004 10:58 Go to previous messageGo to next message
the diff has tacken a bit of a beating lately thought i roated my tyres ther other day aswell and i took the back left brake drum cover thing off to check the pads and just put it back on , and the noise seems to be uncahged and only when going really slow , also when changing gears it is getting quite clunky,,
should i just replcae the diff center i have a spair one to use.
jason
FKN16V
NSW, East Coast
Re: clunky diff which part is it???? Sun, 18 April 2004 11:16 Go to previous messageGo to next message
hemi twofifteen turbo wrote on Sun, 18 April 2004 20:19
i
I would try this first, you may not need to use the other center, it may be wheel bearing issues or might be splines missing of the axles if you have been driving a little erratic (spelling)?
ta2272
Re: clunky diff which part is it???? Sun, 18 April 2004 11:28 Go to previous messageGo to next message
am i up for a whole new diff if the axles are damaged (missing)
jason
ta2272
Re: clunky diff which part is it???? Mon, 19 April 2004 10:05 Go to previous messageGo to next message
got under there today and couldnt really pin point the noise.
wonder if i should just replace the center anyway.
jason
ta22gt
Re: clunky diff which part is it???? Thu, 22 April 2004 02:11 Go to previous message
The other thing it maybe is the backlash on the crownwheel to pinion gear this would be why when you change gears the pressure is reduced and as you let the clutch back out it has to take up the slack on the two gears. No it doesnt nesecarily mean a rebuild but will need to be removed and adjusted any reasonable mechanic should be able to do it and should only cost about $50.
Cheers nev
Previous Topic:3T-GTEU bigend bearing source/problem
Next Topic:42mm Webers VS. 45mm Solexes on 18r-gu
Current Time: Mon Oct 26 08:44:02 UTC 2026
Total time taken to generate the page: 0.006072998046875 seconds
