Toymods » Tech & Conversions » GZE internals int age
ILUSZN
GZE internals int age Mon, 19 April 2004 01:07 Go to next message
Guys,
I did a search and came up blank for me..
I would like to know if the 4AGZE internals (crank, rods, pistons) would all slot into a 4AGE. Or even just the rods and pistons..
Denis
Re: GZE internals int age Mon, 19 April 2004 01:56 Go to previous messageGo to next message
I understand they do, but you would end up with a lower compression ratio which in a NA engine isn't favourable.
ILUSZN
Re: GZE internals int age Mon, 19 April 2004 02:02 Go to previous messageGo to next message
lower compression is what i am after as i would turbo charge it.. Smile. just saves me having to change the engine numbers etc if it all fites... Very Happy
Grega
melbourne.victoria.austra...
Re: GZE internals int age Mon, 19 April 2004 03:42 Go to previous messageGo to next message
depends on the 4AGE.
if its an early type 3 rib with the 40mm setup, no it won't if its the later type with the 7 ribs and 42mm setup, then you can throw the rods and pistons in.
feral4mr2
Bundaberg, Qld.
Re: GZE internals int age Mon, 19 April 2004 05:19 Go to previous messageGo to next message
Freak if you use the gze crank you can put it all in a early 3 rib 4age.
as Grega said though, measure the big ends on your crank, if you lucky and got the 42mm already you dont need to swap cranks.
ILUSZN
Re: GZE internals int age Mon, 19 April 2004 06:09 Go to previous messageGo to next message
Thanks Guys,
Atleast you have Cleared up my Questions. Now just have to find GZE internals..
feral4mr2
Bundaberg, Qld.
Re: GZE internals int age Mon, 19 April 2004 09:41 Go to previous messageGo to next message
Freak just turbo your 4age.... Smile
ILUSZN
Re: GZE internals int age Mon, 19 April 2004 09:48 Go to previous messageGo to next message
Bolting a Turbo kit straight onto a NA engine, Ill leave that to the Swift guys to do.. Ill do this right or not at all. No point just doing it, destroy a perfectly good engine and then spending MORE money.. May aswell get teh internals that are strong enough, compression correct and everything else that goes with turbo charging.
Do it right or dont do it at all. Thats what i think.
feral4mr2
Bundaberg, Qld.
Re: GZE internals int age Mon, 19 April 2004 13:09 Go to previous messageGo to next message
Freak ok, sorry... Confused
Wink
Re: GZE internals int age Mon, 19 April 2004 13:10 Go to previous messageGo to next message
With all the bodgy stuff that goes on nowadays, why not just buy a GZE, and swap the engine numbers? Much easier than swapping all the innards...
shinybluesteel
melbourne
Re: GZE internals int age Mon, 19 April 2004 15:05 Go to previous message
just replace the engine and get the engine number changed on your rego.
i think they will notice the "hairdrier hanging off the side" before they notice a different engine number.
much cheaper, much easier.
arent the NA smallports mechanically identical to the GZEs (except pistons and SC12) anyway?
mrshin, beat me to it.
Previous Topic:engine conversion question
Next Topic:Reground cams
Current Time: Wed Oct 21 02:54:12 UTC 2026
Total time taken to generate the page: 0.0058338642120361 seconds
