Toymods » Tech & Conversions » Reground cams
EZB_Rolla
Reground cams Mon, 19 April 2004 01:58 Go to next message
Could someone please explain what i need to go get this done, and the type of shop to do it. I have a 4age (ae92 100kw) and i want them ground to: 272 / 7.9mm.
Does anyone have th TRD specs for mild cams for the 4a.
[Updated on: Mon, 19 April 2004 02:03]
Re: Reground cams Mon, 19 April 2004 07:46 Go to previous messageGo to next message
you sure you want to regrind a cam for an OHC motor??? what will you do about shims?
better to get a new cam ground, rather than regrinding...
Bill Sherwood
Brisbane / Gold Coast
Re: Reground cams Mon, 19 April 2004 10:50 Go to previous messageGo to next message
A Stellite regrind is okay, I've used them for years.
The cam man grinds away some of the existing lobe and then welds on some very expensive stuf called Stellite with an electric welder, then grinds the new lobe from it's rough shape down to the new larger one.
Kelfords on the Gold Coast do them for about $30 a lobe.
TA22-3SGTE
MACKAY
Re: Reground cams Mon, 19 April 2004 13:09 Go to previous messageGo to next message
You can get a new set of 272 billet cams from Wade Cams for $440 .
There was a topic a while back on this .
Trevor
dar_sbb
Re: Reground cams Mon, 19 April 2004 13:44 Go to previous messageGo to next message
where is wade cams? is there a web site? ph number?
wraith
Albany WA
Re: Reground cams Mon, 19 April 2004 14:27 Go to previous message
(Inset the bit where people tell you to search)
www.wadecams.com kinda obvious when you think about it, ey? Google would have told you this by now. On their site they have the following info-
Wade Camshafts Pty. Ltd.
ABN 62 004 544 996
27 Wells Road,
Oakleigh,
Victoria 3166,
Tel: +61 03 - 9568 0333
Fax: +61 03 - 9568 2633
Next time, please do a search.
Previous Topic:GZE internals int age
Next Topic:Brake shudder? Easy for some!
Current Time: Tue Oct 20 03:58:36 UTC 2026
Total time taken to generate the page: 0.0052130222320557 seconds
