Toymods » Tech & Conversions » 18rc with auto problems
people100
Rocklea qld
18rc with auto problems Mon, 19 April 2004 08:50 Go to next message
i have recently changed my 18rc from manual to auto as my gf cant drive manual....And have a few problems
If you are reversing or driving real slow like 5 km/h or sitting still it flicks from in gear to neitral and back and you have to rev it to like 2000 for it to jump back into gear and then jumps around...What could it be???
wilbo666
Re: 18rc with auto problems Mon, 19 April 2004 09:12 Go to previous messageGo to next message
Low fluid level? Thats how mine acted when the fluid level was low.
people100
Rocklea qld
Re: 18rc with auto problems Mon, 19 April 2004 09:58 Go to previous messageGo to next message
how many litres should they hold..we only put a couple of litres in when we put the box in..ill try topping it up.
wilbo666
Re: 18rc with auto problems Mon, 19 April 2004 10:29 Go to previous messageGo to next message
You can only check the level accurately when it is at operating temperature and still running (don't switch off the motor to check it). Make sure it shows on the stick to start with (should have cold/hot markings, then take it for a drive (get it to operating temp, make sure you go through all the gears etc)... then once its hot check the level and fill it to the top of the hot (then once its cooled down completely, ie overnight, you can use the cold marking on the dipstick as a reference).
celicaboy
Re: 18rc with auto problems Wed, 28 April 2004 08:31 Go to previous messageGo to next message
sounds like it needs a good service... drain the fluid out and put a new filter in it and gasket and new fluid.. if it still does it when you top it up or a lil bit funny do a service on it
people100
Rocklea qld
Re: 18rc with auto problems Wed, 28 April 2004 10:02 Go to previous message
i did solve the problem...was just low fluid.
Previous Topic:Cams for 100kw 4age
Next Topic:ae71/ae86 5 speed
Current Time: Fri Nov 20 20:02:19 UTC 2026
Total time taken to generate the page: 0.01736307144165 seconds
