Toymods » Tech & Conversions » Brake shudder? Easy for some!
HighRolla
icon8.gif  Brake shudder? Easy for some! Mon, 19 April 2004 10:00 Go to next message
My friends ae92 corolla has shuddery brakes. I put new front pads. Inspected the discs but they didn't look like they needed machining. If you hit the brakes on the flat they usually don't shudder, but if you're going down a hill or even up and hit the brakes you can feel the shudder quite bad (through pedal, no shudder through steering wheel). Is this a common problem, the discs look fine but maybe slightly too shiny (maybe should have hit with the emery) . It has solid front discs that are only $54 each on this website. Is it worth getting them machined or just buy new ones? The rears appear ok (but then again so did the fronts) .
Is there any other cause of brake shudder or is it most likely to be the front rotors.
www.discpads.com.au
I put new front rotors on my ae82 and it fixed the shudder, but this shudder is more intermitent and on my ae82 rotors you could visibly see the unevenness of the rotor, turned out they would be below minimum thickness if they were machined.
[Updated on: Mon, 19 April 2004 11:18]
HighRolla
Re: Brake shudder? Easy for some! Mon, 19 April 2004 12:27 Go to previous messageGo to next message
Anyone for brake shudder question?
Re: Brake shudder? Easy for some! Mon, 19 April 2004 13:53 Go to previous message
Make sure everything's done up tight, it can even be caused by wheels that don't quite fit properly not pulling the rotors in against the hub. But for the tiny bit of cost/effort involved, get the rotors machined, 20 bucks ain't gonna break the bank is it?
Previous Topic:Reground cams
Next Topic:1uz has a slight miss at idle
Current Time: Mon Oct 19 10:57:59 UTC 2026
Total time taken to generate the page: 0.10395097732544 seconds
