Toymods » Tech & Conversions » Need help from people with 4age + turbo
Simon-AE86
Banned user
ADELAIDE - The Drift City
Need help from people with 4age + turbo Mon, 19 April 2004 10:25 Go to next message
Hey all, i am currently in the process of chucking a turbo onto my smallport 4age, I have a few questions so far.
I am using the RB20 turbo on a custom manifold that me and A-Spec will make and i want to know where i should get feeds and drains for the turbo?
I have blocked off the heater hoses (i dont even have a heater in my 86) so nothing to tap into there...
Oil return into the sump wont be hard, can drill and weld a fitting there but was curious about feed along with water feed and return.
Pic's ofpeoples setups would be great please
feral4mr2
Bundaberg, Qld.
Re: Need help from people with 4age + turbo Mon, 19 April 2004 11:07 Go to previous messageGo to next message
Freak here is a link to the HK$ turbo manual for the AW11. http://marc.thefuse.net/mr2/HKS/index.htm
even though you dont have a AW11 they should help.
i tee'd my water lines into the heater lines. i have heard of people useing the lines that go to the thottle body, but personaly i dont like that idea.
the heater outlets would still be on your engine?
best way i've found for the oil feed line. i did mine like this after my first attempt of having a brass fitting and tee peice with the oil pressure sender and turbo feed in the block, the fitting ended up cracking in the block. as many others that did it that way have.
*these are not my pics*
http://www.windsorworld.net/ww/Images/OilFeedLine.jpg
http://www.windsorworld.net/ww/Images/TurboMounted.jpg
Simon-AE86
Banned user
Re: Need help from people with 4age + turbo Mon, 19 April 2004 12:18 Go to previous messageGo to next message
thanks buddy, so if u didnt use a brass T fitting due to them breaking, what did you use?
could i get away without running any water lines to the turbo or what?
Simon
feral4mr2
Bundaberg, Qld.
Re: Need help from people with 4age + turbo Mon, 19 April 2004 12:35 Go to previous messageGo to next message
Freak i used a steel fitting and braided lines like in those pics.
i have seen water cooled turbo's with-out the coolant lines...
shinybluesteel
melbourne
Re: Need help from people with 4age + turbo Mon, 19 April 2004 15:13 Go to previous messageGo to next message
simon, a good place to get the oil feed from is a T- piece from the oil pressure sender,
if you have a water cooled turbo, hook up the water cooling! from what i have read, it is definately worth it.
see if you can borrow "maximum boost" from someone, i just bought it, very helpful!
Grega
melbourne.victoria.austra...
Re: Need help from people with 4age + turbo Mon, 19 April 2004 19:18 Go to previous messageGo to next message
simon, tee off the oil pressure sender switch like folks have suggested. if you're not keen on the brass cracking fittings speedflow (www.speedflow.com.au) make alloy fittings to suit. the hole is 1/8 NPTF FWIW.
re; water fittings, i'm using my heater hoses (as my gas convertor also uses these - i'd run a tee out of the back of the fitting that sits in the back of the head,for supply and return, well, tee into the pipe that goes along side the block back to to the water pump assy (depending on your setup)
Simon-AE86
Banned user
Re: Need help from people with 4age + turbo Mon, 19 April 2004 22:16 Go to previous messageGo to next message
OK thanks for that, One other thing, what exhaust size should i go? since this isnt goingto be a HP storming motor i think 3 inch is a little overkill (and hard to fit on ae86) so was thinking 2.5 inch.
fatmr2
Re: Need help from people with 4age + turbo Mon, 19 April 2004 23:44 Go to previous messageGo to next message
If i can jam a 3 inch exhaust into an mr2 i cant see why you couldnt put one in an 86?
But yeah, go 2.5 inch.
EVOSTi
cambo
      no
Re: Need help from people with 4age + turbo Tue, 20 April 2004 06:30 Go to previous messageGo to next message
a few ppl are running 3 inch exhausts on their sprinter, i will be soon, it can be done.
thats a really neat set-up on the mr2, if i wasnt such a tight ass i would do something like that rather than a brass T-piece and rubber hoses. Rolling Eyes
Grega
Re: Need help from people with 4age + turbo Tue, 20 April 2004 07:17 Go to previous messageGo to next message
mine will be 2.5" as i'm not shooting for HP heroes either...
feral4mr2
Bundaberg, Qld.
Re: Need help from people with 4age + turbo Tue, 20 April 2004 08:30 Go to previous messageGo to next message
EVOSTi wrote on Tue, 20 April 2004 16:30
just keep an eye on that Tee piece. luckily mine cracked just in boss on the thread and only had a minor oil leak, you dont want it to crack right off and lose your engine...
oh, and i vote the 2.5" too.. Smile
[Updated on: Tue, 20 April 2004 08:31]
Simon-AE86
Banned user
Re: Need help from people with 4age + turbo Tue, 20 April 2004 08:54 Go to previous messageGo to next message
2.5inch it is, making it dump off the turbo and then exit straight out the passenger side Very Happy
should be nice and loud
I just scored a free S13 cooler and BOV too...
feral4mr2
Bundaberg, Qld.
Re: Need help from people with 4age + turbo Tue, 20 April 2004 09:09 Go to previous messageGo to next message
mine isnt very loud at all, 2.5" dump, pipe and flex pipe to a 3" lukey muffler..
http://www.members.aol.com/feral4mr2/images/zor1.jpg
Simon-AE86
Banned user
Re: Need help from people with 4age + turbo Tue, 20 April 2004 14:45 Go to previous messageGo to next message
just another thing, My motor has great compression, but the valve stem seals are not in perfect cond, how will this be affected by the adding of turbo + boost?
Simon
shinybluesteel
melbourne
Re: Need help from people with 4age + turbo Tue, 20 April 2004 15:23 Go to previous messageGo to next message
in my opinion:
you will probably get more blowby, but smoke shouldnt pour out of the exhaust pipe (if you think about it) due to the boost pushing past the stem seals when the inlet valves are closed, and the exhaust trying to do the same thing due to there being a turbo causing much greater exhaust port pressure.
i think it shouldnt be much worse if you dont push it, and if you are turboing a 10:1 or so motor, then you wont want to run crazy boost anyway.
Simon-AE86
Banned user
Re: Need help from people with 4age + turbo Wed, 21 April 2004 08:03 Go to previous messageGo to next message
that makes sence, thanks for that buddy.
Simon
EVOSTi
cambo
      no
Re: Need help from people with 4age + turbo Wed, 21 April 2004 11:20 Go to previous messageGo to next message
how will boost push past the valve stem seals when the valves are closed? that makes no sense to me. i dont think there will be any difference to the valve stem seal leakage.
feral4mr2
Bundaberg, Qld.
Re: Need help from people with 4age + turbo Wed, 21 April 2004 11:29 Go to previous message
i see no reason why boost would effect the engine with worn valve stem seals either.
other than the puff of smoke at start-up which would happen boosted or not.
Previous Topic:"G" series diff ratio availability?
Next Topic:RWD 4agze alternator?
Current Time: Thu Oct 15 04:20:22 UTC 2026
Total time taken to generate the page: 0.091195106506348 seconds
