Toymods » Tech & Conversions » Brightness Of Dash Lights
schmitt
Brightness Of Dash Lights Mon, 19 April 2004 12:19 Go to next message
hey everyone before you ask i have turned the dimmer up all the way. i was just wondering if there was anyway to increase the brightness of the globes in the dash. i have even tried replacing them. any advice would be really appreciated.
Re: Brightness Of Dash Lights Mon, 19 April 2004 13:04 Go to previous messageGo to next message
i'd suggest lining the inside of the dash cluster with foil.
increasing the bulb wattage will increase heat, and thats not exactly a good thing...
if the foil does not work enough, then maybe a little higher wattage, or possible an extra bulb (or LED's?)
Re: Brightness Of Dash Lights Mon, 19 April 2004 13:16 Go to previous messageGo to next message
or just replace all the dash globes with new ones of same size.. the bulbs might just be getting dim....
ae86drift
sydney.au
Re: Brightness Of Dash Lights Mon, 19 April 2004 13:44 Go to previous messageGo to next message
maybe remove those little led caps they put on to gove colour
the green ones yeah?
gold28
Madrid - Spain
Re: Brightness Of Dash Lights Tue, 20 April 2004 00:26 Go to previous messageGo to next message
The old celicas were bad when they were new. You could try replacing the bulbs and also cleaning the copper contacts on the back of the instruments where the bulbs mount. Other than that, look into modifying them in some way.
Some people have used LED in place of the bulbs with good results. I have made new gauge faces from opaque plastic so that they appear back-lit. This is a really good solution but takes some time to get right. I will try and post a pic for you soon.
schmitt
icon14.gif  Re: Brightness Of Dash Lights Wed, 21 April 2004 07:23 Go to previous messageGo to next message
thanks for all the advice everyone. i am just asking cause i have changed the colour of the faces on the guages. made the background white and numbers black and put in blue led's. it is ok but is a bit dull. thanks again for the advice
gold28
Madrid - Spain
Re: Brightness Of Dash Lights Thu, 22 April 2004 00:41 Go to previous messageGo to next message
Well thats a little different then.
LED's won't work too well off the dimmer. You should really run them through a regulated power supply if you want tham to dim.
If you don't want to do it that way, leave the dimmer on full (can't dim them) and keep adding LED's until it is bright enough.
You may find that painting the inside of the gauge cans white instead of tourquoise may help.
CrAiGzEE
south of the big smoke
Re: Brightness Of Dash Lights Thu, 22 April 2004 06:00 Go to previous messageGo to next message
i painted the blue plastic with chrome paint made a huge difference
buy since then i have put clear white perpex instead of the metal dials, all done professionally, using super bright blue LEDs, my problem now is not being bright enuff but being to bright! it lights up my whole cabin!!!
ill take a picture and show ya!
edit: bugman did or the white dials not i
[Updated on: Thu, 22 April 2004 06:03]
schmitt
Re: Brightness Of Dash Lights Thu, 22 April 2004 07:07 Go to previous messageGo to next message
Thanks guys i will try some of your advice. thanks very much
migoreng
Cabramatta, Sydney
icon11.gif  Re: Brightness Of Dash Lights Thu, 22 April 2004 10:47 Go to previous message
i'm a n00b about car electronics...
so how can i change my 2003 camry orange dash lights?
maybe wire a few other light colours to the wires..and make a switch for green, blue, or red?? a different colour for each night...ahhh...
is that possible?
which dashbaord warranty would be void if i did it?
Previous Topic:2TG Piston Identification
Next Topic:JZA70 1JZ Problems
Current Time: Sat Oct 17 01:43:29 UTC 2026
Total time taken to generate the page: 0.0086019039154053 seconds
