Toymods » Tech & Conversions » 86: going from carby to efi setup? The hiddens.....?
no_tofu_speed
Jab what?!!?!
86: going from carby to efi setup? The hiddens.....? Mon, 19 April 2004 21:21 Go to next message
An 86, changing form the standard aussie 4ac to an efi engine, wether be a 4age, gze or even 3sge-fam.
Other than changing the actual engine, bolting it up....
What is the "hidden" things that:
1. MUST be changed....
2. SUGGESTABLE to be changed?
eg. fuel tank (EFI. is it a MUST?) and al the other stuff whatever it is that must be changed or fiddled with going from a mechanical to ECU'd engine.
toyoda
Re: 86: going from carby to efi setup? The hiddens.....? Mon, 19 April 2004 23:06 Go to previous messageGo to next message
If its a FWD engine :
Exhaust MAnifold
Inlet Manifold
Throttle position sensor - rotated
All engines :
Clutch pipe to clear exhaust ( 90 Degree connector works)
Throttle cable
EFI Pump
Thermostat housing ( I didnt bother putting on in )
Wiring up speed sensor in Speedo ( Not strictly necessary)
Oxy Sensor
Toyoda
rob-ae86
campbelltown
Re: 86: going from carby to efi setup? The hiddens.....? Tue, 20 April 2004 00:37 Go to previous messageGo to next message
the efi tank isnt a must i think its the way you mount the pump
have a look at another sprinters fuel pump to get an idea
Henn
Rosanna, Melb
Re: 86: going from carby to efi setup? The hiddens.....? Tue, 20 April 2004 14:28 Go to previous messageGo to next message
You need a high pressure efi pump.
You can:
- Run an efi pump directly out of your stock sprinter pickup. This is dodgy and will cause fuel surge if your tank is low.
- run a small low-pressure lift pump filling a surge tank and then feed your efi pump from the surge tank. Much better, but good luck fitting all that crap under a sprinter rear end.
- Pay lots for an efi sprinter tank
- Cut open your stock tank, get baffles welded in and then mount your choice of in-tank efi pump.
- Or run it on LPG.
Then make sure you replace all rubber fuel hose between the pump and fuel pressure regulator with high-pressure efi stuff. And plumb the return line from the fuel rail back into the stock tank return line. The factory metal lines are big enough to flow enough fuel.
gearb0x
Re: 86: going from carby to efi setup? The hiddens.....? Wed, 21 April 2004 22:17 Go to previous messageGo to next message
Re: cutting and welding the tank
Do you know any places in melb that would do this? i have a 4 wheeler with a steel tank that needs a new bottom in it (damn rust)
Phill
FKN16V
NSW, East Coast
Re: 86: going from carby to efi setup? The hiddens.....? Wed, 21 April 2004 22:35 Go to previous message
gearb0x wrote on Thu, 22 April 2004 08:17
Phill
Any metal fabrication workshop should be able to help, Just ring around and ask,
Steve
Previous Topic:3s-gte rev cut at 5500? WTF?
Next Topic:Mod hlep for a new 4th gen' guy?
Current Time: Sun Oct 18 21:01:48 UTC 2026
Total time taken to generate the page: 0.006256103515625 seconds
