Toymods » Tech & Conversions » 3t-gte thermostat housing sensors
SRacin
Christchurch, New Zealand
3t-gte thermostat housing sensors Mon, 19 April 2004 23:32 Go to next message
Hi People,
Just wonder if anyone knew excatly what all the sensors are on an oil cooled 3tgte thermostat housing.
There are 3 across looking form the front, and one in the oil lines.
1st from left -single blade plug - I have wired to temp gauge
2nd across - single blade connector - ?
3rd across - 2 pin plug - ?
Now I know one of them is to ground the cold start injector? which one is this and what does the other one do?
As for the one in the oil lines, is this a pressure switch for the dummy light?
Logan
CLG
Perth, Western Australia
Re: 3t-gte thermostat housing sensors Tue, 20 April 2004 02:52 Go to previous messageGo to next message
Cold Start Timer Sensor: brown plug located under the thermostat housing.
Water Temp Sensor: green plug located under thermostat housing
Water Temp Guage Sender: Spade plug located between the two plugs mentioned above
Oil Temp Warning Light: under the three plugs mentioned above
Oil Pressure Guage Sender: Located on the RHS of the block under the dizzy.
Clint
SRacin
Re: 3t-gte thermostat housing sensors Tue, 20 April 2004 03:56 Go to previous message
Sweet,
Thank you,
As I assumed, one of mine has been change to aftermarket, but no biggy as Im running link computer.
Thanks for that.
Logan
Previous Topic:Welder in Canberra?
Next Topic:T50 Gear box - Speedo gears - Experts needed
Current Time: Sun Oct 18 11:54:34 UTC 2026
Total time taken to generate the page: 0.0039808750152588 seconds
