Toymods » Tech & Conversions » Door trim removal on Camry Sv21
Dopey_7
The Shire, Sydney
Door trim removal on Camry Sv21 Tue, 20 April 2004 01:15 Go to next message
Intending on installing central locking, sound deadening the doors and installing some 6.5" splits. Problem: I can't get my front door trims off my Camry. Confused . I undid the first 4 screw's but i don't know how to get the window winder thing off?? And then how to get it off from there?
cheers,
Jeff
[Updated on: Tue, 20 April 2004 01:16]
cam_RA40
Launceston, Tasmania
haha, funny little head!
Re: Door trim removal on Camry Sv21 Tue, 20 April 2004 01:23 Go to previous messageGo to next message
normally there is a small wire thing that holds it on, it is a semi circle shape with bent bits on both ends. I normally use a flat head screw driver on both the bent ends and push. if you understand me Razz
Toml
Re: Door trim removal on Camry Sv21 Tue, 20 April 2004 02:20 Go to previous messageGo to next message
cam_RA40 wrote on Tue, 20 April 2004 10:53
Exactly what he said...
Push the door trim back away from the window winder, shove a small flat head screw driver in there and lever out the metal clip, then it will all come off easily.
Tom
Iceman
Re: Door trim removal on Camry Sv21 Tue, 20 April 2004 05:06 Go to previous messageGo to next message
Coming from an SV21 owner and having done all this the hard way(myself), take the map pockets off and mount the mid drivers between the lower left corner of the door and the window winder. So mark on the trim where the winder goes in a circle so u dont have any issues later.
User an MDF spacer screwed seperately to the trim. You'll have to cut a hole in the metal behind the trim, but don't worry it won't screw up ur door opening and closing.
Mount the Tweaters on the A-pillars as close to the dash as possible but so they are pointed directly at the opposite seat/side of the car.(the driver's side will obviosly be higher.
Any other Questions, PM me.
Cheers, Pete.
Toml
Re: Door trim removal on Camry Sv21 Tue, 20 April 2004 05:24 Go to previous messageGo to next message
Iceman wrote on Tue, 20 April 2004 14:36
Or, even better, mount the tweeters in the kick panels pointing towards the opposite head-rest to get the most equal distancing from them. Smile
Tom.
Camry_omega
Campbelltown, NSW, Austra...
Re: Door trim removal on Camry Sv21 Tue, 20 April 2004 08:26 Go to previous messageGo to next message
I found the bast way to remobe the winders was using a piece of coat hanger wire with a small hook on the end.
Toml
Re: Door trim removal on Camry Sv21 Tue, 20 April 2004 08:48 Go to previous message
I've removed them 4 times in the last couple of days so i'm getting quite quick at it Very Happy
I've found that if you get a flat head screwdriver, slip its thinnest side between the door and the window winder and move it sideways... it pops off the little metal clip very easily. Smile
Tom.
Previous Topic:1uzfe in a corolla
Next Topic:3tgte metal head gasket
Current Time: Thu Oct 22 06:56:34 UTC 2026
Total time taken to generate the page: 0.005108118057251 seconds
