Toymods » Tech & Conversions » tire hitting strut
dar_sbb
tire hitting strut Wed, 21 April 2004 04:38 Go to next message
got 17" on my st162 and the tire is hitting the strut
(215/45/17)
put king springs superlows
what can be dun?
[Updated on: Wed, 21 April 2004 05:15]
CLG
Perth, Western Australia
Re: tire hitting strut Wed, 21 April 2004 05:31 Go to previous messageGo to next message
Change the wheel offset! This can be done illegally and simply by installing wheel spacers, and ensuring your wheel studs still have enough thread on them to keep the wheel nuts. Or you could buy the correct offset wheels?!!!
cam_RA40
Launceston, Tasmania
haha, funny little head!
Re: tire hitting strut Wed, 21 April 2004 06:53 Go to previous messageGo to next message
I had a similar problem, spacers are supposably safe (but i don't think legal) if the wheel nut can still do 6 turns. The other possibility is putting a small dent in the strut where the tyer goes past, pretty dodgy i know, I would only try it if the tyer is just brushing against the strut, make sure you don't dent it too much so the shockie can't come out. Or maybe if your tyers are significantly wider than the wheel you could fit thinner tyers eg 205's rather than 215's.
BlackSupra
Re: tire hitting strut Wed, 21 April 2004 07:07 Go to previous messageGo to next message
install stock springs.
dar_sbb
Re: tire hitting strut Wed, 21 April 2004 07:08 Go to previous messageGo to next message
thanks guys
dont think that the 205's will be small enough... need to see bout the spacer... i need around a inch tho
SeptemberSquallIndustries
Re: tire hitting strut Wed, 21 April 2004 07:18 Go to previous messageGo to next message
dar_sbb wrote on Wed, 21 April 2004 17:08
thanks need to see bout the spacer... i need around a inch tho
Rolling Eyes
dar_sbb
Re: tire hitting strut Wed, 21 April 2004 07:21 Go to previous messageGo to next message
i tired with both lowered and stock
only effects the back
cam_RA40
Re: tire hitting strut Wed, 21 April 2004 08:22 Go to previous messageGo to next message
If it is about an inch you have major problems! I thought you ment more like 1 or 2 mm. I rekon the offset of your rims is way off.
celicaboy
Re: tire hitting strut Wed, 21 April 2004 08:27 Go to previous messageGo to next message
yeah you have wrong offset wheels...
did you buy them 2nd hand?
fi so if they r off a wrx or a subaru then there is ya problem
GT4_Steve
Sutherland, Sydney
Re: tire hitting strut Wed, 21 April 2004 14:09 Go to previous messageGo to next message
it seems like you have an ST185 wheel offset (38mm)
I had this problem when I stuck my GT4 wheels on my ST162. Depending on what width tyre you have on the back you can get away with it...I did, but not the front. If you manage to get an inch let me know, purely vanity for me though :) damn shitty offset laws, why have big fat guards and not be able to fill them. Anyone want to give me custom Simmons?????????????
dar_sbb
Re: tire hitting strut Thu, 22 April 2004 00:36 Go to previous messageGo to next message
when i put new rear struts it stuffed up the ride high (lifted the car bout 2-3cms and camber went off) gonna see if i can get another set from a wrecker to see if there fit
dar_sbb
Re: tire hitting strut Fri, 23 April 2004 05:05 Go to previous message
Are there ne other struts that fit the st162??
eg. the 202's or 184s or corolla...?
[Updated on: Fri, 23 April 2004 05:18]
Previous Topic:strut combinations
Next Topic:Raising Boost/Fuel/Ignition cut on 7M-GTE ????
Current Time: Sun Oct 25 13:50:11 UTC 2026
Total time taken to generate the page: 0.045161008834839 seconds
