Toymods » Tech & Conversions » Installing a turbosmart GBCV.
boris
On probation
Brisbane, Queensland
Installing a turbosmart GBCV. Wed, 21 April 2004 09:35 Go to next message
I'm about to install a turbosmart gated boost controller onto my 3TGTEU, before i do anything i just want to double check with somebody more knowledgeable.
Really all i need is for somebody to say yes this is the line that it must be installed on that runs from the pressure source and the wastegate actuator!
http://www.lawntonss.eq.edu.au/home/jshaw66/t1.jpg
http://www.lawntonss.eq.edu.au/home/jshaw66/t2.jpg
http://www.lawntonss.eq.edu.au/home/jshaw66/t3.jpg
Lastly, the instructions mention briefly removing the stock boost controller solenoid, where abouts do i find that?
Thanks for any help!!!
boris
On probation
Re: Installing a turbosmart GBCV. Wed, 21 April 2004 10:06 Go to previous messageGo to next message
I'm about to go cut it..... Shocked
Re: Installing a turbosmart GBCV. Wed, 21 April 2004 12:57 Go to previous messageGo to next message
well - it should be reasonably obvious what pipe feeds pressure to the actuator?
trace pipe backwards from wastgate actuator ... cause those photos are.... well ... a bit difficult to read.
gold28
Madrid - Spain
Re: Installing a turbosmart GBCV. Thu, 22 April 2004 00:37 Go to previous messageGo to next message
I'ts hard to tell from the photos, but it looks like your wanting to cut into the coolant lines.
The wastegate actuator will be a small tin-can looking thing mounted on the side of the turbo about 30-40mm in diameter. It will have a pushrod coming out of one end and a pipe from the other. The actuator pipe usually feeds from a fitting on the compressor housing.
if when you cut it, you get a hand full of water or oil, you know you have stuffed up.
Re: Installing a turbosmart GBCV. Thu, 22 April 2004 01:15 Go to previous messageGo to next message
gold28 wrote on Thu, 22 April 2004 08:37
Pure class Smile Having said that, he's right. Do the line going between the compressor housing and the actuator.
boris
On probation
Re: Installing a turbosmart GBCV. Thu, 22 April 2004 03:05 Go to previous message
yeah i realise the photos are shithouse, i havn't actually done it yet, don't have the time.....
Previous Topic:What fluids do all you 1ggte owners use??
Next Topic:3T-GTEU bigend bearing source/problem
Current Time: Fri Nov 20 21:22:29 UTC 2026
Total time taken to generate the page: 0.0075490474700928 seconds
