Toymods » Tech & Conversions » 4agze cam specs
fatmr2
4agze cam specs Thu, 22 April 2004 00:49 Go to next message
I'm after the standard cam specs for the aw11 4agze?
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: 4agze cam specs Thu, 22 April 2004 02:36 Go to previous messageGo to next message
Same as 100kW, check here for all the specs:
http://www.billzilla.org/carindex.htm
ae95
Re: 4agze cam specs Thu, 22 April 2004 05:44 Go to previous messageGo to next message
Yep. a Good upgrade is to use the bigport cams which have slightly more lift and duration.
._T_.
Re: 4agze cam specs Thu, 22 April 2004 05:46 Go to previous messageGo to next message
aw11 s/c is the bigport. the aw11 & ae86 already get the 240 duration cams (& a 0.5 increase in lift!! don't get too excited!!)
T
feral4mr2
Bundaberg, Qld.
Re: 4agze cam specs Thu, 22 April 2004 10:07 Go to previous messageGo to next message
as far as i knew/read the aw11 4agze is spose to have the 7.1mm lift 232* duration, not like the early 3 rib bigport 4age that had the 7.56mm lift 240* duration.. as it says on here:
http://www.club4ag.com/faq%20and%20tech_pages/4A-G E%20camshaft_story.htm
i have both sets in my shed (4agze and early 4age), whats the best way to measure the difference?
[Updated on: Thu, 22 April 2004 10:12]
EVOSTi
cambo
      no
Re: 4agze cam specs Thu, 22 April 2004 11:49 Go to previous messageGo to next message
best way is to use a dial gauge, but you prob could use verniers.
feral4mr2
Bundaberg, Qld.
Re: 4agze cam specs Thu, 22 April 2004 11:59 Go to previous messageGo to next message
mmmm.. well i can use a dial guage from work. i'll have to take the cams to work with me.
i am wondering now though come to think of it, how would you use a dial guage to measure from the shaft to the lobe center? maybe it will be easier to use my verniers?
thanks man.
EVOSTi
cambo
      no
Re: 4agze cam specs Sat, 24 April 2004 07:46 Go to previous message
to measure lift with verniers you have some stands to put the cam on, sort of like a thick peice of steel with a V cut out of the top for the cam to sit in, you have one at each end of the cam, they must be the same height. then you just centre the guage on the back of the lobe and turn the cam. its handy if you got the proper stands for the cam bust most ppl/workshops dont.
Previous Topic:Best Clutch Kit
Next Topic:Boost Problems with a 4agze
Current Time: Sun Oct 18 22:58:55 UTC 2026
Total time taken to generate the page: 0.0087389945983887 seconds
