Toymods » Tech & Conversions » Clutch Slave q's
STR8 2.8
Clutch Slave q's Thu, 22 April 2004 06:32 Go to next message
When i pinch the boot on the clutch slave arm it squirts dirty clutch fluid out. This is bad, yes?
Should the little arm pushing the fork be on a weird angle. It doesn't exactly sit parallel to the body of the cylinder. It sort of sticks out at an angle to hit the hole in the fork. Is this ok?
This is on an ma61 with what could be a w57...
bbaacchhyy
Re: Clutch Slave q's Thu, 22 April 2004 07:22 Go to previous messageGo to next message
Yes.
No. Arm should be straight. Could either be that it is not sitting in the slave cyl properly, or there is the problem with the clutch fork itslef.
A rebuild kit for the slave cyl cost me $12.00 from the local brake place. A bit of 1200 W&D, some metho, and easy as pie.
Michael B
HighRolla
Re: Clutch Slave q's Thu, 22 April 2004 07:30 Go to previous messageGo to next message
Or a new slave should be around $30 if your lazier
STR8 2.8
Re: Clutch Slave q's Thu, 22 April 2004 13:52 Go to previous message
cheers, fellas
Previous Topic:Autometer Shift Light - Tach wire? my birthday pressie is confusing me :D
Next Topic:1JZ-GTE Missing Erratically
Current Time: Mon Oct 19 18:04:29 UTC 2026
Total time taken to generate the page: 0.0058169364929199 seconds
