Classifieds » Miscellaneous » FS 4 spot alloy calipers RX7 series 4/5
gerryb
FS 4 spot alloy calipers RX7 series 4/5 Thu, 22 April 2004 07:10 Go to next message
gbaulch@hn.ozemail.com.au
or 0431 387 005
Henn
Rosanna, Melb
Re: FS 4 spot alloy calipers RX7 series 4/5 Thu, 22 April 2004 12:05 Go to previous messageGo to next message
How much you asking?
Where in Oz are you?
Hen
gerryb
Re: FS 4 spot alloy calipers RX7 series 4/5 Thu, 22 April 2004 13:19 Go to previous messageGo to next message
I want $250 for the pair, I'm in brisbane, but can cod to Melbourne no problem. Had another pair and cod'd them to Melbourne recently.
chris philpott
hobart
Re: FS 4 spot alloy calipers RX7 series 4/5 Thu, 22 April 2004 13:29 Go to previous messageGo to next message
Hi! Gerry its Chris in Hobart, there is a guy on the tech section after rx7 injectors and I gave him your emailfor contact.
Cheers Chris Smile
gerryb
Re: FS 4 spot alloy calipers RX7 series 4/5 Thu, 22 April 2004 14:09 Go to previous messageGo to next message
Thanks Chris
gerryb
Re: FS 4 spot alloy calipers RX7 series 4/5 Sat, 24 April 2004 13:59 Go to previous messageGo to next message
Anyone else still got 1 pair left
gerryb
Re: FS 4 spot alloy calipers RX7 series 4/5 Mon, 26 April 2004 02:54 Go to previous messageGo to next message
Price drop to $240
0431 387 005
[Updated on: Mon, 26 April 2004 02:56]
pepsicola
Re: FS 4 spot alloy calipers RX7 series 4/5 Mon, 26 April 2004 05:54 Go to previous messageGo to next message
u have the rotors as well?
gerryb
Re: FS 4 spot alloy calipers RX7 series 4/5 Mon, 26 April 2004 06:21 Go to previous messageGo to next message
These calipers will take a 22 to 24mm thick rotor, so there's heaps of rotors you can use with them, e.g. Nissan 180sx (sr20det model),Maxima,Fwd 93 on Bluebird, 22mm thick tarago and celica rotors, Mitsubishi Magna 22mm thick rotors, etc etc.
It depends on the application and struts you are mounting them to, you go to the DBA online catalogue and it has all the dimensions of the rotors and you find the ones that suit your mounting requirements.
Oh and no I don't have the RX7 rotors with them, (the RX7 rotors usually aren't used in conversions to other vehicles).
pepsicola
Re: FS 4 spot alloy calipers RX7 series 4/5 Mon, 26 April 2004 06:30 Go to previous messageGo to next message
yeh, i was going thru the DBA catalogue after my post.
the original rx7 rotors are 22mm thick. so u sure they take up to 24mm? i figure the best i've seen so far is the magna one being 24mm, and slightly smaller in Dia.
what's the condition of the calipers? needs rebuild?
and what's the shipping cost to 2131 NSW?
gerryb
Re: FS 4 spot alloy calipers RX7 series 4/5 Mon, 26 April 2004 09:39 Go to previous messageGo to next message
Oh okay must be 22mm only, just know a well known nissan conversion guy uses magna rotors in a conversion he does with these calipers. Calipers are straight off series 4/5 RX7's as removed. all pins clips etc are there.
gerryb
Re: FS 4 spot alloy calipers RX7 series 4/5 Mon, 26 April 2004 09:44 Go to previous message
cod'd a pair to Melbourne the other day, cost was $20, I guess NSW would be similar or cheaper
Previous Topic:wrecking ke10's ( also ae71 & ke35)
Next Topic:Gen 3 SW20 bits
Current Time: Sat Oct 24 14:45:37 UTC 2026
Total time taken to generate the page: 0.0066630840301514 seconds
