Toymods » Tech & Conversions » wiring for coil ballast
praetor
wiring for coil ballast Thu, 22 April 2004 10:24 Go to next message
I'm half way through wiring up the ignition on the celica (3sgte genII) but I can't work out how to wire in the ballast for the coil. Its not on any diagrams I can find... any suggestions?
[Updated on: Thu, 22 April 2004 10:30]
Re: wiring for coil ballast Thu, 22 April 2004 16:16 Go to previous message
depends if you want to switch out the ballast during starting??
usually, pwer comes from IGN, then goes thru ballast, then goes to coil, since you are trying to reduce the coil voltage from 14 to less..
for switching out during starting, a wire from either starter solenoid, or the start position on ignition swith, straight to the coil will give higher coil voltage.. just be careful of circuit loops.
Previous Topic:LOCK DIFF RA40??
Next Topic:Comparison - 2TGEU to 3TGTEU
Current Time: Fri Oct 23 16:34:27 UTC 2026
Total time taken to generate the page: 0.0045580863952637 seconds
