Toymods » Tech & Conversions » Fan shroud
demuire
Ipswich
Fan shroud Thu, 22 April 2004 13:51 Go to next message
I'm about to go get a thermofan for my car, and was thinking of how to mount it...
I've been told that it would probably be good to look at making a shroud, apparently would help cooling a fair bit. I've also been told that the thermofan basically becomes redundant and is a hindrance past 40km/h...
How do people usually mount their thermofans? Flat flush against the radiator? Or make a shroud and mount the fan to that? If so, do you usually cover up the rest of the radiator?
That seems to be quite popular (judging by images on Google) but I would have thought it would be a handicap to the engine and radiator because so much of the radiator is covered up?
Any ideas?
[Updated on: Fri, 23 April 2004 21:37]
Re: Fan shroud Thu, 22 April 2004 16:12 Go to previous messageGo to next message
have a look for alan's pics of his radiator ... or mayebe I can get some of mine tomorrow.
what sort of car do you have?
if you can mount the thermos dead flush, you probabloy dont need a shroud.
also, the thermos will not be turned on when you're travelling 40+km/hr, so should provide minimal hinderance
demuire
Ipswich
Re: Fan shroud Thu, 22 April 2004 20:54 Go to previous messageGo to next message
Alan...? I've got a KE35...
people100
Rocklea qld
Re: Fan shroud Fri, 23 April 2004 09:47 Go to previous messageGo to next message
if your keen ill get ya one maid....Only will cost ya the price of material but will take a few days...ley me know if ya want one and ill have to organise and measure how much room you have left...
demuire
Ipswich
Re: Fan shroud Fri, 23 April 2004 11:00 Go to previous messageGo to next message
Was speaking to someone today about the shroud and apparently because of the resistance of air going through the actual core of the radiator the opening at the back (in the shroud) only needs to be like 1/6 the surface area of the actual radiator before it becomes any hindrance (wow).
Have not properly measured my core yet, but rough measurements say it's 12" from top to bottom, so will probably get a 10" fan (the Davies Craig 10" fan is 11.5" tall including the built in shroud). The radiator is only slightly wider than it is tall so should be heaps more than 1/6, should be more than enough Smile
So will probably make one similar to the one in the pic above. Shouldn't be hard, just make an aluminium box and cut a big round hole Smile
Ben: I'll measure everything up and maybe give it a go, if I have dramas I'll let you know, but THANKS HEAPS for the offer Smile BTW Hows that wiring going? If you need help I'll try to come round once my car is on the road (hopefully in the next week or two)
[Updated on: Fri, 23 April 2004 11:03]
CLG
Perth, Western Australia
Re: Fan shroud Fri, 23 April 2004 13:12 Go to previous messageGo to next message
Shrouded radiators work more effectively than others as they have air directed through the radiator, definately use some type of shroud. Try using the standard shroud for the radiator, and fitting the thermo fan to that opening, it will cool much more effectively than just the thermo fan on the radiator. I have a KE radiator shroud if you need one too?!
Clint
demuire
Ipswich
Re: Fan shroud Fri, 23 April 2004 21:23 Go to previous messageGo to next message
Clint: Don't have the original shroud but have access to one, but looking at the original one I can't think of any way to mount the thermofan and have it seal, which was why I didn't pursue that avenue. Will try to make one out of aluminium like:
http://www.rondavisradiators.com/1130-1-angle.jpg
Most definately won't look as nice (was going to rivet the corners together...) but it should work Smile
Thanks Smile
demuire
Ipswich
Re: Fan shroud Sat, 24 April 2004 15:48 Go to previous messageGo to next message
Made my shroud today:
http://images5.fotki.com/v70/photos/1/12090/787736/04250001-vi.jpg
Am quite happy with it Smile
Grega
melbourne.victoria.austra...
Re: Fan shroud Sat, 24 April 2004 21:53 Go to previous messageGo to next message
fook i have to concur mate that is an AWESOME looking piece of work well done hope it performs as good as it looks!
V8_MA61
Re: Fan shroud Sun, 25 April 2004 08:02 Go to previous messageGo to next message
But what is the use of a flush mount shroud and a flush mount thermo??(sorry if thats not the case with yours..looks it tho) demuire that is directed to...
it makes the fan no more efficient than if it was without a shroud at all.
If someone wants to host pics ill show the ma61 cooling system im designing. 4 core chev radiator with 2 gt4 fans JUST for cooling..not incl 12" DC fan for a/c.
[Updated on: Sun, 25 April 2004 08:04]
Re: Fan shroud Sun, 25 April 2004 08:19 Go to previous messageGo to next message
fook's is how mine is setup - fan sucks air thru entire radiator face rather than just the fan area...is also helpful at low airspeeds (e.g. in traffic)
demuire
Ipswich
Re: Fan shroud Sun, 25 April 2004 08:41 Go to previous message
Yeah the shroud isn't as deep as I'd like it, but that's all that space permits. It's actually 30mm deep, which should be enough considering the fan itself covers more than 50% of the face of the radiator...
Previous Topic:Engine number swap
Next Topic:problems with 4agze
Current Time: Fri Oct 23 16:33:44 UTC 2026
Total time taken to generate the page: 0.0055508613586426 seconds
