Toymods » Tech & Conversions » 4AGE thermofan wiring
demuire
Ipswich
4AGE thermofan wiring Thu, 22 April 2004 22:21 Go to next message
If I'm not mistaken the sensor switch for the thermofan on the 4AGE (AE92 if that helps at all) is usually closed (on) and open (off) when it gets hot? If so... How do you wire it up so that the fan comes on when the engine gets hot? I've heard something about using 2 relays, but can't seem to figure out how the wiring would go...
Grega
melbourne.victoria.austra...
Re: 4AGE thermofan wiring Thu, 22 April 2004 22:39 Go to previous messageGo to next message
fook, there is a dual position relay you can use for this - basically when the unit is powered (so the switch is NC) it supplies power to 87, otherwise when it goes NO - it supplies power to 87a
seemed to work ok for me... Smile
demuire
Ipswich
Re: 4AGE thermofan wiring Thu, 22 April 2004 22:59 Go to previous messageGo to next message
A dual position relay... sounds funky Smile Available from like Repco/Autobarn etc? Fairly certain SuperCheap doesn't have it, they only have simple relays...
So I would assume you run the fan relay to 87a instead of 87 so that when the thermal switch turns off (when it gets hot) then 87a gets powered?
demuire
Ipswich
Re: 4AGE thermofan wiring Thu, 22 April 2004 23:21 Go to previous messageGo to next message
Found one I think:
http://www.dse.com.au/cgi-bin/dse.storefront/40885 31e00277d3c2741c0a87f9c06b4/Product/View/P8035
Does that sound about right? Can't seem to find any DPDT's in the automotive style ones... But since I'm only switching one pole...
*edit* ah, got "poles" and "throws" mixed up, looks like that should be the correct one Smile
[Updated on: Fri, 23 April 2004 00:55]
Toobs
Re: 4AGE thermofan wiring Fri, 23 April 2004 01:29 Go to previous messageGo to next message
All you need is SPDT relay
Jaycar has two different SPDT auto relays
30A - here
60A - here
You can also get relay bases - here
demuire
Ipswich
Re: 4AGE thermofan wiring Fri, 23 April 2004 01:54 Go to previous messageGo to next message
I would assume a 30A relay should be enough for a single 12" fan? I sure hope it doesn't pull any much more than 30A! Smile
Thanks Smile
Grega
Re: 4AGE thermofan wiring Fri, 23 April 2004 01:59 Go to previous messageGo to next message
toobs is 1 trillion percent on the money - and yep - 30A fine.
Re: 4AGE thermofan wiring Fri, 23 April 2004 02:27 Go to previous messageGo to next message
toobs has much of teh love for jaycar.
demuire
Ipswich
Re: 4AGE thermofan wiring Fri, 23 April 2004 03:43 Go to previous messageGo to next message
Drew up a diagram, am assuming I will also need another relay (normal SPST) to make sure the fan doesn't come on when IGN goes off.
Grega
Re: 4AGE thermofan wiring Fri, 23 April 2004 05:14 Go to previous messageGo to next message
yes fook correct.
normally relay for that will suffice.
sideshow
Re: 4AGE thermofan wiring Fri, 23 April 2004 09:49 Go to previous messageGo to next message
its easy
all u need is one normal relay supplying power toi a 2nd relay that turns on the fan
the 2nd relay is green
look at any toyota fusebox if there is a green relay there
then its usually a normally closed relay that runs the thermo
demuire
Ipswich
Re: 4AGE thermofan wiring Fri, 23 April 2004 11:01 Go to previous messageGo to next message
sideshow: don't have the original fuse box, hence the "custom" install Smile
sideshow
Re: 4AGE thermofan wiring Fri, 23 April 2004 12:00 Go to previous message
yer but if u need a relay that is normally closed just get one form wreckers or old fusebox
or u can buy one from auto shop
just ask for a normally closed
or a switchin type relay
Previous Topic:Widebody Camry 3S-GTE Conversion
Next Topic:air flow
Current Time: Sun Oct 18 20:04:09 UTC 2026
Total time taken to generate the page: 0.0060169696807861 seconds
