Toymods » Tech & Conversions » RWD 4A-GE Water Lines
dorikin ichiban
Auckland, New Zealand
RWD 4A-GE Water Lines Fri, 23 August 2002 00:40 Go to next message
With the RWD 4A-GE Water Lines that go towards the back of the motor.
Can someone tell me why the top water line (the one that goes to the back of the head) has usually has a T-piece with a hose going somewhere else (where does that hose goto?)
I know the bottom water line goes to the heater.
Re: RWD 4A-GE Water Lines Fri, 23 August 2002 01:21 Go to previous messageGo to next message
Not 100% sure but from memory there was a hose around there with a T piece that was to heat the throttle body/idle up valve.
Hope this helps.
Joel
feral4mr2
Bundaberg, Qld.
icon7.gif  Re: RWD 4A-GE Water Lines Fri, 23 August 2002 01:31 Go to previous messageGo to next message
Freak the top pipe (from the head) the small tee off it goes to the throttle body (warm up/idle down) the bottom pipe (big one off the water pump) has a small tee, this goes to the throttle body as well (warm up/idle down) return.
the lines for the heater are off the thermostat housing/rear of head.
dorikin ichiban
Re: RWD 4A-GE Water Lines Fri, 23 August 2002 02:11 Go to previous messageGo to next message
I think you guys have missed the plot.
Federal: I think you are thinking of your 4age which will have the thermostat ontop of the gbox ala FWD. Where as the RWD setup has it just behind the water pump.
Below is a pic taken from the 4A-GTE article in the tech section
http://www.garagedori.com/misc/rwd4ageblock.jpg
I want to know where the top water line on the left hand side (rear of the block) T's off to.
._T_.
Re: RWD 4A-GE Water Lines Fri, 23 August 2002 02:25 Go to previous messageGo to next message
john,
i thought it went to the heater core.. but thinking about it there are 2 pipes - one big one (heater?) and one smaller one... that hooks back into the small top tube on the waterpump piping...
i'm obviously going to have to check my ae86 chassis manual....
T
feral4mr2
Bundaberg, Qld.
icon7.gif  Re: RWD 4A-GE Water Lines Fri, 23 August 2002 03:34 Go to previous messageGo to next message
Freak sorry mate cant help you then, that is completely different to the ze in my aw-11.
but the top line (smaller one) on mine that comes from the small block, that comes of from the head (alternator top braket mounts to it), tees to the throttle body, dont know if its a help, but i've done my 4agte and i still needed the two lines to the throttle body.
IRA11Y
Club Member
Re: RWD 4A-GE Water Lines Sun, 25 August 2002 00:13 Go to previous message
the small pipe at the rear connects to a pipe coming off the rear water housing on the back of the head that holds the two sensors.
Previous Topic:RA65 Ute?
Next Topic:Will JDM AE86 front brake bolt-on??
Current Time: Thu Oct 22 14:51:24 UTC 2026
Total time taken to generate the page: 0.0051751136779785 seconds
