Toymods » Tech & Conversions » need info on a 5k
esv8
kyabram,victoria
need info on a 5k Sat, 24 April 2004 00:44 Go to next message
I have a ke20 corolla with a 5k engine in it. Now i need to know what they originally came out of, what capacity it is and would a 4k head fit?. Also it has a blown head gasket and need to know if a 4k gasket would do as the spare parts joint here can't find a code for a 5k gasket. Last of all i'm in victoria and want to find out if i can legally get it registered without a engineers report?. Any help would be most appreciated as i want to get it goin and registered A.S.A.P.
Re: need info on a 5k Sat, 24 April 2004 02:29 Go to previous messageGo to next message
geez, a bit of a search would have gotten you all this info....
but rather than flame you...this time....
liteace
1500cc
yes, but only if head is from a dished piston 4K, otherwise you'll have wayyy too high compression.
no, 4K has 5.5mm smaller bore!!!!!!!! you NEEEEED a 5K HG
i doubt it. KE20 came with 1200CC 3K, 1500CC 5K is... 25% mroe capacity. you SHOULD get it engineered.
bmak
Re: need info on a 5k Sat, 24 April 2004 04:19 Go to previous messageGo to next message
Any place that stocks ACL (BR270MT) is the part no. for the gasket.
Roadworthy places in Vic will have no problems with the 5k in a KE20
esv8
kyabram,victoria
Re: need info on a 5k Sat, 24 April 2004 12:45 Go to previous messageGo to next message
Thanks for your help brad, much appreciated. Sorry for not knowing about all things four cylinder as i have been driving an injected V8 for the past 2 years, this is all new to me. Thanks for the help. Smile
Re: need info on a 5k Sat, 24 April 2004 23:02 Go to previous messageGo to next message
Can always be a bit nasty and grind the engine number off the 5K, put a 4K one on there, most people would be hard pressed to tell the difference... That said, you should be able to find someone to give you a RWC on the 5K. The guy I get mine from didn't have any issues with the idea of a 4AG in a KE70, so long as I fit a cat converter and unleaded filler neck (WHY! you can't buy leaded fuel here no more - are they worried I might top it up with diesel??) Evil or Very Mad
bmak
Re: need info on a 5k Sun, 25 April 2004 00:16 Go to previous message
My roadworthy bloke doesnt have a problem with my 4AG in my KE70 either.
Most are pretty good in vic if it bolts in using factory parts & isnt turbo.
Previous Topic:VSV controller
Next Topic:Caliper rebuild, How much roughly?
Current Time: Thu Oct 22 22:04:38 UTC 2026
Total time taken to generate the page: 0.0045599937438965 seconds
