Toymods » Tech & Conversions » What Brakes and Suspension to put on a KE20
1973_KE20
What Brakes and Suspension to put on a KE20 Sat, 24 April 2004 01:07 Go to next message
What brakes and suspension can i put on a KE20 1973 Corolla, it has disc brakes on the front. Also what do i have to do to put a 4AGE into it?
wombat
Laverton, Vic
Re: What Brakes and Suspension to put on a KE20 Sat, 24 April 2004 09:29 Go to previous messageGo to next message
Brakes and suspension my dad put in his race car where as follows.
Front
Datsun 200b Front Rotors
Corona Twin spot Callipers
Rose joint Suspension
Rear
Standard leaf springs
Custom Rotors
Datsun 120y Calipers with custom mounts.
That's all Dose the job really well.
rotorace
Re: What Brakes and Suspension to put on a KE20 Sat, 24 April 2004 11:54 Go to previous messageGo to next message
ill bump this, as id also like to know some options.
wombat; how did your dad fit those front brakes?
what options are workshops interstate offering?(not sa)
wombat
Laverton, Vic
Re: What Brakes and Suspension to put on a KE20 Sat, 24 April 2004 13:04 Go to previous messageGo to next message
with a lot of messing around, But they work really good.
Mind you I should tell you this was all fitted to our KE-20 race car, so we had camber and that. But I think the pretty much just went straight on if not he would have taken the whole front rotor set up off the Datsun and replaced it onto the front end.
Re: What Brakes and Suspension to put on a KE20 Sat, 24 April 2004 13:13 Go to previous messageGo to next message
it depends if you are keeping the KE20 struts or not really...
it also depends what rims you will be running..
some rumours are.
camira vented front discs will bolt to the KE20 hub. have seen this with volvo 4 spots.
honda civic discs, redrilled for KE20 hub pattern.
there are also some others that will slip over the hub and be held on by the rim, ala skyline etc.
grab the DBA catalog, work out what rim size you want, and go from there.
to begin with, you can swap in the KE30/KE70 discs and calipers... caliper pistons are the same size, but the discs are 218mm vs 200mm for the KE15/KE20 discs.
SRacin
Christchurch, New Zealand
Re: What Brakes and Suspension to put on a KE20 Sun, 25 April 2004 03:07 Go to previous message
Hi people Ive been over this a few times with my 71 ke25,
try this link
http://forums.toyspeed.org.nz/viewtopic.php?t=992& amp;highlight=ke25+brakes
and do some searching on that forum, I think Ive posted a few times.
Summary of link is the use of s1 rx7 struts...
Logan
Previous Topic:problems with 4agze
Next Topic:VSV controller
Current Time: Fri Oct 23 10:10:34 UTC 2026
Total time taken to generate the page: 0.0048418045043945 seconds
