Toymods » Tech & Conversions » **URGENT, NEED 18RG CAM DOWEL TONITE**
Mr DOHC
**URGENT, NEED 18RG CAM DOWEL TONITE** Sat, 24 April 2004 09:24 Go to next message
i need a 18RG dowel pin in the front of the cam {the one that locates the gear}
i just dropped mine into the sump and i cant take the sump off unless i have an engine crane.
need help
0405131728
i live in rochedale brissie
SRacin
Christchurch, New Zealand
Re: **URGENT, NEED 18RG CAM DOWEL TONITE** Sun, 25 April 2004 03:09 Go to previous messageGo to next message
do you really want that dowel floating around inside your motor???
try a magnetic pic up, or even and oil change, it might float out....
Logan
munki
Gold Coast
Re: **URGENT, NEED 18RG CAM DOWEL TONITE** Sun, 25 April 2004 04:05 Go to previous messageGo to next message
did you ring nev last night?
I was just wondering wouldnt the pin go into the bottom of the timing case or the middle of the timing case more likely than in the sump?
Mr DOHC
Re: **URGENT, NEED 18RG CAM DOWEL TONITE** Sun, 25 April 2004 04:38 Go to previous messageGo to next message
i had to pull both xmembers off and drop the sump and i got it out, but now i have worse problems.
i have chronic valve seat recession, i put a 0.03mm under the lobe to see how much valve lash i had and it wouldnt go under I2, I3 or I4, that means its holding the valves open, UH OH SPAGHETTIO'S, new head
yes i rang nev but he couldnt help till late tonite
ed_ma61
Lost in the K hole
Re: **URGENT, NEED 18RG CAM DOWEL TONITE** Sun, 25 April 2004 06:15 Go to previous messageGo to next message
LOL Laughing
seriously, ive done exactly the same thing. i thought, hey, im only 150km from home, its only Xmas eve, its only 1030pm, why not try changing my cam timing at this dimly lit servo!!
uh oh, spaghettiohs... plonk, lost the dowel into the timing cover somewhere! managed to dodge together a quick fix with a piece of 5mm bolt i had floating around in the boot, cut down to size with some wire cutters.
later, on xmas day, i tried my darndest to fish the dowel back out, to no avail - its now down 10,000km residing in the bottom of the timing cover with zero problems.
meanwhile, i think youll find 5.1mm stock steel rod is an exact replacement (its a common dowel size). i can send some up to you, but its hardly going to arrive tomorrow Rolling Eyes
ed
Mr DOHC
Re: **URGENT, NEED 18RG CAM DOWEL TONITE** Mon, 26 April 2004 00:14 Go to previous message
fixed it
i ended up pulling the sump off and fishing it out, now the sumps leaking real bad
Previous Topic:ferrari kits for MR2 SW20
Next Topic:RX7 Injectors
Current Time: Thu Nov 19 15:28:24 UTC 2026
Total time taken to generate the page: 0.0056829452514648 seconds
