Toymods » Tech & Conversions » Drag soarer and boost
andrewvibert
Forum Sponsor
Shepparton (Vic)
Drag soarer and boost Fri, 23 August 2002 02:19 Go to next message
How much boost can I get out of a 1jzte in a Soarer for just a short period of time. (drag)Engine is standard other than exaust and aircleaner. (standard turbos).
ytri
Preston
Re: Drag soarer and boost Fri, 23 August 2002 03:36 Go to previous messageGo to next message
Sorry Andrew, bit off the topic, but how often do you get 1jz's in your shop?
andrewvibert
Forum Sponsor
Shepparton (Vic)
Re: Drag soarer and boost Fri, 23 August 2002 04:33 Go to previous messageGo to next message
I dont often get 1JZ's for stock but I have supplied a couple to giantomato for his project.(one water damaged). I do have on the way a manual JZA70 half cut. It should be here next week.
ytri
Preston
Re: Drag soarer and boost Fri, 23 August 2002 04:48 Go to previous messageGo to next message
How much for the front cut? I want to replace my engine soonish and id kinda prefer if it was already in shepp without having to cart it there myself.
By the way i found out the other day that you were like best man at my aunties wedding or something a long time ago!
thunderbird1
Sydney Australia
Re: Drag soarer and boost Fri, 23 August 2002 04:57 Go to previous messageGo to next message
With fuel cut defender, and fuel press reg... u can run 17-18 psi easy for some runs down the drag stripe. Might be an idea to get it dyno'd at see how much difference the jump from 14-18 makes. If your intake and intercooler are standard, it will prob not make any difference because the heat increase will cancell out the hp.
As for people who say a 1J stock turbo can't do more than 14 psi Wink .. show me the broken bits! Razz
Luke
kingmick
Banned by his request
moved to tamworth
Re: Drag soarer and boost Fri, 23 August 2002 08:28 Go to previous messageGo to next message
the only national race car that had a 1j in it now has a 13b turbo, was running from 22psi to 29psi of boost with a standard bottom end. this lasted for a full season like this{grabbed a piston.} until they bolted another import bottom end in it overnight at a race meeting. anything under 20psi would be fine. as long as its kept cool and has plenty of oil. long term keep it at 18 psi and it will be fine. they got about 650hp out of it with 26 psi. this was with two t3 and a motec etc.
make sure it uses a big oil cooler.
mick
andrewvibert
Forum Sponsor
Shepparton (Vic)
Re: Drag soarer and boost Fri, 23 August 2002 22:32 Go to previous message
THanks all
Previous Topic:engine code question
Next Topic:pics of my turbo conversion so far
Current Time: Sun Oct 25 19:01:59 UTC 2026
Total time taken to generate the page: 0.0039019584655762 seconds
