Toymods » Tech & Conversions » 3tgte in a ta22?
Phat22
3tgte in a ta22? Sat, 24 April 2004 16:59 Go to next message
Guys
I've seen it done heaps but still don't know how hard it is to do! Can anybody provide the exact info on all the modification needed to put this engine in the 22? Is it hard, expensive????? Any info or links to other threads (couldn't find one with exact info) would be greatly appreciated. Cheers Lee
Grega
melbourne.victoria.austra...
Re: 3tgte in a ta22? Sat, 24 April 2004 21:48 Go to previous messageGo to next message
a 3TGTEU will basically bolt into a TA22. HEAPS of folks have done this on here - from what I understand the passenger side mount fouls the turbo drain pipe and needs a bit of work.
http://forums.toymods.org.au/index.php?t=msg&t h=9020&rid=664&S=87f3983046c961fcec9c8dd66 83b338c&pl_view=&start=0#msg_72085
have a read of that too
you've also gotta rig up fuel system, w5x series gearbox, tailshaft, gearbox mounts, exhaust, and wire up the computer.
it will be a bit of work and if you want to save on cost embrace DIY.
CLG
Perth, Western Australia
Re: 3tgte in a ta22? Sun, 25 April 2004 04:11 Go to previous messageGo to next message
In it's simplist install, utilising the standard TA22 gearbox, yes, you will still have problems with the LH engine mount. You can either choose to move the cross member mount the small amount it needs to clear the rubber mount, or modify the rubber mount - I once used a modified Datsun 200B engine mount without moving the crossmember mount, to good but not perfect effect.
Clint
Re: 3tgte in a ta22? Sun, 25 April 2004 04:14 Go to previous messageGo to next message
Cant you just use a standard 3T mount and just block the oil return and make another one on the sump?
TA22 GT
Re: 3tgte in a ta22? Sun, 25 April 2004 12:08 Go to previous message
Check out my site, it has all you need to know about fitting a 3T GTE in a TA22.
Check under my car and "Technical info", I have also put the full 3T GTE wiring diagrams there as well.
Cool1,
3T GTE mounts are thicker than the stock 2T mounts, so they cant be used without a small mod to the brackets.
I modified both side to allow the use of the stronger 3T GTE mounts.
But no doubt using 2T ones is ok as well.
Simon
Previous Topic:MA61 cooling system - custom?
Next Topic:can i keep using my electronic dash?
Current Time: Sun Oct 25 19:01:45 UTC 2026
Total time taken to generate the page: 0.0052521228790283 seconds
