Toymods » Tech & Conversions » 20v shortblock,L/port head,quad throttle+ecu?
ae86slideways
warrnambool VIC
icon9.gif  20v shortblock,L/port head,quad throttle+ecu? Sat, 24 April 2004 17:37 Go to next message
Does anyone know if a 100kw 4age ecu could run a large port head with dummy weber setup for throttle bodies,if you adapted throttle position sensor to carb shaft?Also anyone tryed largeport head on 20valve bottom end ?Im toying with this idea as a budget way of getting around the awkward 20valve conversion points,like dizzy position,water outlets etc.
Got any other combos that work on a budget mixing and matching parts?I have complete 20v(no ecu etc)and rwd 88kw with loom and ecu etc,plus weber manifold and hyperpak ignition.
Grega
melbourne.victoria.austra...
Re: 20v shortblock,L/port head,quad throttle+ecu? Sat, 24 April 2004 21:39 Go to previous message
i doubt it - it may work but not very well - you'd have to find a position to grab manifold pressure signal from for the 100kw ECU - sure, running the big port head shouldn't be much of an issue - remembering you also have two air temp sensors also to deal with!
Previous Topic:Caliper rebuild, How much roughly?
Next Topic:Problems !!
Current Time: Tue Oct 20 23:48:20 UTC 2026
Total time taken to generate the page: 0.22009801864624 seconds
