Toymods » Tech & Conversions » oil leak
kristian
oil leak Fri, 23 August 2002 03:10 Go to next message
sprinter blue top 4age
after oil ( mobil 1 5w ) and filter changed oil leaks, didnt have leaks before.
thunderbird1
Sydney Australia
Re: oil leak Fri, 23 August 2002 04:59 Go to previous messageGo to next message
oil's too thin Wink leaks out the holes in ur motor! Razz
I once had a 4ac with no oil leaks. I put mobil one in it and lost 5 L's in 400km's! Figure that.
4ag's don't need mobil one, unless it has just been rebuilt. in my opinion u could save money and just use something like Castrol Magnetic or something similar.
Luke
kristian
Re: oil leak Sun, 25 August 2002 04:22 Go to previous messageGo to next message
something like a 15w maybe ?
castrol gtx3
IRA11Y
Club Member
Re: oil leak Sun, 25 August 2002 05:33 Go to previous messageGo to next message
Can you actually see oil leaking on the ground or are you just topping it up because its low?
synthetic oil in 4AGE's tends to burn off due to the engine tolerances not being designed for such a light oil so over time you will loose some oil like in Lukes case.
In particular mobil 1 in my experience is not a suitable oil for the 4AGE, I have used it on new engine that Ive had to pull apart within 1000Kms and have seen an unusually high level of wear on the bearings and oil loss problems as mentioned earlier. I recommend you use something with a higher grade like Penrite 30 or 50.
kristian
Re: oil leak Wed, 28 August 2002 04:35 Go to previous message
irally
yes it leaks, only happens when the car has been parked over a long period, overnight, oil spots in the morning.
took your advice and had oil changed to penrite HPR 30, engine seems to have more grunt ..hmmm weird.
Now my clutch is slipping, 1st gear goes to 4k 5k rpm, then drops, like the speed is lagging ...hahaha. Other gears arent as bad, just have to take it easy now...
Previous Topic:to front mount or not to frount mount????
Next Topic:air bypass valve question (4agze)
Current Time: Fri Nov 20 10:24:43 UTC 2026
Total time taken to generate the page: 0.0040950775146484 seconds
