Toymods » Tech & Conversions » stalling 2tgeu
lilcrash
ipswich queensland
stalling 2tgeu Sat, 24 April 2004 22:30 Go to next message
ive just got my car moving and it doesnt want to run with the efi vacuum line one, wat should i do??? also wen ever i hit the pedal it just dies and sounds like its just been hit with a gutful of air.
any suggestions plz
thanx
Re: stalling 2tgeu Sun, 25 April 2004 02:37 Go to previous messageGo to next message
Is the air flow meter working? What happens if you move the flap with your finger?>
lilcrash
ipswich queensland
Re: stalling 2tgeu Sun, 25 April 2004 02:47 Go to previous messageGo to next message
i dont have an air flow meter connected, ive got a pod bolted staight to the efi
ive just tried it with the air flow meter and it hasnt made a diffrence, does it matter if it is plugged in to the computer???
also wen ever i take my foot of the clutch it stalls even wen ive got it at 5000 rpm, neideas of wat copuld cause this???
thanx
[Updated on: Sun, 25 April 2004 03:07]
munki
Gold Coast
Re: stalling 2tgeu Sun, 25 April 2004 03:54 Go to previous messageGo to next message
plug it in.
Re: stalling 2tgeu Sun, 25 April 2004 03:55 Go to previous messageGo to next message
Laughing Does it matter if its plugged in Laughing
Re: stalling 2tgeu Sun, 25 April 2004 04:01 Go to previous messageGo to next message
the ECU needs signals from the AFM and the TPS on the throttle body to calculate correct fueling for the engine ... as well as air and coolant tempreture - along with an ignition signal to work out RPM.
i'd stop trying to run the motor right now
without these two sensors working, when above idle there's no way the engine will get the right amount of fuel. if you keep this up, there's a chance you'll run the engine extremely lean and break/melt/damage something important - like a piston.
munki
Gold Coast
Re: stalling 2tgeu Sun, 25 April 2004 04:02 Go to previous messageGo to next message
my car isnt driving anywhere. i have these wheel things should i put them on?
Re: stalling 2tgeu Sun, 25 April 2004 04:03 Go to previous messageGo to next message
munki wrote on Sun, 25 April 2004 14:02
No you dont need these. They just make the car look good Very Happy
lilcrash
ipswich queensland
Re: stalling 2tgeu Sun, 25 April 2004 09:23 Go to previous messageGo to next message
the reason the afm isnt connected is because im using a haltec not the standard computer, there isnt a plug for the afm on it
and its actually running rich
if neone has neideas can they plz reply
thanx
people100
Rocklea qld
Re: stalling 2tgeu Sun, 25 April 2004 09:34 Go to previous messageGo to next message
Id say take it and get it professionally tuned...no point stuffing around if you dont actually know where you need to start.
Re: stalling 2tgeu Sun, 25 April 2004 10:15 Go to previous message
...well, your listed symptoms sounded like running lean (particularly the run out of fuel when you load up the engine bit)
so... was the ECU previously used on this or similar motor? you have MAP sensor plumbed in?
and is wired up as per a haltech wiring diagram for your ECU?
<http://www.haltech.com.au/downloads.htm>
rich could be a number of things:
fuel pressure too high
warm up enrichment too high or temp sensor not connected
wrong injectors
timing wrong
other sensors (map or TPS) not right
...i'd start at basics first - is it hooked up right, are the physical things right, before progressing onto how to drive the haltech with a laptop...
Previous Topic:open wheels diffs
Next Topic:3sge rear wheel drive conversion
Current Time: Sun Oct 25 02:36:11 UTC 2026
Total time taken to generate the page: 0.078872919082642 seconds
