Toymods » Tech & Conversions » 1g-gte turbo intake flange pipe urgently needed!!
Yeeehah
icon9.gif  1g-gte turbo intake flange pipe urgently needed!! Fri, 23 August 2002 03:38 Go to next message
I urgently need the part mentioned for this thread. I have just changed the ct12's for another pair of ct12's assuming it should bolt straight on, but it doesn't. The screw holes where the intake pipe bolt up are wider.
So the turbo intake flange pipe off the original ct12's does not fit. The distance between the two screw holes from the furthest end must be no less than 650mm.
I hope this makes sense!
Is there an alternative??
Ash
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon2.gif  Re: 1g-gte turbo intake flange pipe urgently needed!! Fri, 23 August 2002 04:09 Go to previous messageGo to next message
The Gen 2 and Gen 3 intake pipes are larger. Looks like you got the turbos, so you'll need the pipes off one of those engines.
kingmick
Banned by his request
moved to tamworth
Re: 1g-gte turbo intake flange pipe urgently needed!! Fri, 23 August 2002 08:40 Go to previous messageGo to next message
the cheap way to do it is to cut the flange off and put on the flanges you need! liverpool exhast {chevy or jim} will have the flanges you need! the best way is to have a custom manifold made.
mick
Yeeehah
Re: 1g-gte turbo intake flange pipe urgently needed!! Sat, 24 August 2002 08:35 Go to previous messageGo to next message
Can any exhaust place do this?
i don't know much about this sorta stuff.
kingmick
moved to tamworth
Re: 1g-gte turbo intake flange pipe urgently needed!! Sat, 24 August 2002 10:20 Go to previous message
most could do it! but only a few will do a great job. if you want a custom made manifold you would make it in stainless equal lenght . then jet coat the manifold and turbine housing. this is the best way but also the most expensive costing about $1600 for single turbo or $2000 for twin turbo. to cut your flanges of and weld new ones on would cost about $300 that would be just supply.
mick
Previous Topic:Is JDM extractor good?
Next Topic:Sprinter hub
Current Time: Fri Oct 23 22:16:13 UTC 2026
Total time taken to generate the page: 0.011743783950806 seconds
