Toymods » Tech & Conversions » Electronic guru's : Modifying ACIS
BlackSupra
icon4.gif  Electronic guru's : Modifying ACIS Sun, 25 April 2004 12:26 Go to next message
"Acoustic Control Induction System:
The ECU controls the position of the intake air control valve based on input signals from the throttle angle (VTA) and engine RPM (Ne). The VSV, which controls the vacuum supply to the actuator, is normally closed and passes vacuum to the actuator when it is energized by the ECU."
When the valve is open im led to believe the ECU advances the timing as well.
The question i ask is, how difficult is it to rig up some form of dodgy electronic interceptor to change the point at which VSV receives power(or is earthed)? Like an adjustable pot to either bring the VSV into play earlier or later in the rev range?
Easy? hard?
Feel free to shoot me down if you may so wish, but a flat spot in my dyno graph needs fixing Wink
Re: Electronic guru's : Modifying ACIS Sun, 25 April 2004 12:58 Go to previous messageGo to next message
if you ran an aftermarket ECU that had programable outputs then it would probably be very easy to turn the vacuum solenoid for the ACIS on or off at a point of your choosing on a 2D/3D map.
... but for a stock install it's being controlled by code in the factory ECU... (e.g. hardwired)
also, if you modified the signals from the TPS (or VTA as you call it) or RPM then all manner of interesting nad possibly unhelpful things might happen...
maybe you should have a chat to Ed_MA61 about using ECUs to control devices under the bonnet? as he's obviously in that mode of thought judging by recent posts.
to answer your Q: easy if you have non-factory ECU, hard otherwise...
Re: Electronic guru's : Modifying ACIS Mon, 26 April 2004 01:25 Go to previous messageGo to next message
It would be quite possible to make a separate controller to operate the valve separately, thing is, why? Manufacturers have a knack of making those things change at a pretty good time anyway. Leave it disconnected, then connected, take a dyno pull of each, and see where it crosses. Cool
BlackSupra
Re: Electronic guru's : Modifying ACIS Mon, 26 April 2004 07:30 Go to previous messageGo to next message
mrshin wrote on Mon, 26 April 2004 11:25
Thats what i planned to do.
But im also planning some decent headwork. I figured the stock location would be perfect for a stock motor, not always a modified one.
Re: Electronic guru's : Modifying ACIS Mon, 26 April 2004 08:16 Go to previous messageGo to next message
Run ITBs you fag. No ACIS needed.
BlackSupra
Re: Electronic guru's : Modifying ACIS Mon, 26 April 2004 08:40 Go to previous messageGo to next message
i choose to be stubborn like Ed.
I figure this is cheaper as well Smile
Re: Electronic guru's : Modifying ACIS Mon, 26 April 2004 09:39 Go to previous messageGo to next message
gianttomato wrote on Mon, 26 April 2004 16:16
Respect Smile Means you don't have to have a Ford part on your car too Razz
Re: Electronic guru's : Modifying ACIS Mon, 26 April 2004 12:34 Go to previous messageGo to next message
Ahhh. Although, if you're planning on doing any worthwhile engine work, the the previous point about having other, more pressing engine management issues might come in handy Evil or Very Mad
BlackSupra
Re: Electronic guru's : Modifying ACIS Mon, 26 April 2004 12:36 Go to previous messageGo to next message
Yes, yes i know.
But in a interim state im thinking that it may be useable......or maybe i should just do it all at once.
ed_ma61
Lost in the K hole
Re: Electronic guru's : Modifying ACIS Mon, 26 April 2004 12:38 Go to previous messageGo to next message
BlackSupra wrote on Mon, 26 April 2004 18:40
huh? dont rope me into this buddy, youre on your own!!... i just bought some ITB's Twisted Evil Twisted Evil Twisted Evil
as for the ACIS - i doubt youll find its the cause of that flat spot. ive fiddled mine quite a bit and has next to no impact on that 'step'
as mentioned above, it needs TUNING Laughing
Yeah, the unfortunate thing that I, along with thousands of others, have learnt many times over is that it's always best to spend far more than you want to in one hit Mad
ed_ma61
Lost in the K hole
Re: Electronic guru's : Modifying ACIS Mon, 26 April 2004 12:40 Go to previous messageGo to next message
justcallmefrank wrote on Mon, 26 April 2004 19:39
Twisted Evil Twisted Evil Twisted Evil Twisted Evil
BlackSupra
Re: Electronic guru's : Modifying ACIS Mon, 26 April 2004 12:43 Go to previous messageGo to next message
How did u fiddle?
The only way you can possibly fiddle with it is by altering the resistane to the VSV valve and make it open at a different time.
ed_ma61
Lost in the K hole
Re: Electronic guru's : Modifying ACIS Mon, 26 April 2004 12:45 Go to previous messageGo to next message
vsv is either on or off... so whaddya do?... hook up your own switch and see what happens
BlackSupra
Re: Electronic guru's : Modifying ACIS Mon, 26 April 2004 12:52 Go to previous message
considered that didnt rate it much.
mmm i need a real job and a real ecu.
Previous Topic:76 crown weight
Next Topic:Convert KE20 stud pattern to 114.3 PCD?
Current Time: Wed Oct 21 02:56:14 UTC 2026
Total time taken to generate the page: 0.0071170330047607 seconds
