Toymods » Tech & Conversions » fluctuating idle
TA22
fluctuating idle Sun, 25 April 2004 19:17 Go to next message
i have a 2tgeu, and when the engine is warm, the idle fluctuates between 500rpm and 1500.
the car will be idling at about 800 to 1000rpm. and when it warms up, the idle rises to 1500 and drops really low, and keeps looping like this. only happens on idle. any ideas?
sensor problem?
tps, afm, temp??
[Updated on: Mon, 26 April 2004 05:02]
FKN16V
NSW, East Coast
Re: fluctuating idle Mon, 26 April 2004 03:32 Go to previous messageGo to next message
Clean your throttle body and check and double check for air leaks, your tps might out of alignment, how does it drive.
If the tps is out of alignment it'll over fuel or under fuel majority of the time throughout the rev range, especially under load.
Ozzie
Re: fluctuating idle Mon, 26 April 2004 03:36 Go to previous messageGo to next message
My 4AGE does the same thing. Can sit quite happily (esp. after a long drive) at 700rpm or can consistantly sit as high as 1300 Sad
TA22
Re: fluctuating idle Mon, 26 April 2004 05:07 Go to previous messageGo to next message
well id have to say, power wise the car feels really weak, but its a very smooth drive. ive never had the car on the road before, so i dont have anything to compare it to. basically its gutless to 4000rpm. then theres a little power surge from then on in.
any ideas on how to check the tps?
i sprayed stuff over the manifold and found no air leaks... dunno
i jus hope im not leaning out the engine and doing damage to it
celicaboy
Re: fluctuating idle Mon, 26 April 2004 11:13 Go to previous message
check tps? adjust it down.. my cordia does that it was worse until i adjusted the tps now it only does it a lil.. i can adjust it down a bit more but cbf
Previous Topic:Convert KE20 stud pattern to 114.3 PCD?
Next Topic:Willwood calipers?
Current Time: Sat Oct 17 07:07:18 UTC 2026
Total time taken to generate the page: 0.005230188369751 seconds
