Toymods » Tech & Conversions » is this normal? (ma61 clutch question)
is this normal? (ma61 clutch question) Mon, 26 April 2004 05:14 Go to next message
say I've just completely installed the engine, gbox, and all clutch items, then I've filled up the master cylinder.
is it normal for there to be absolutely no back pressure at all on the clutch pedal?
I know the system will need a serious bleed, but there is no pressure at all
YelloRolla
On your mum!
Re: is this normal? (ma61 clutch question) Mon, 26 April 2004 05:20 Go to previous messageGo to next message
Doesn't sound normal. Don't panic until the system is bled tho.
Re: is this normal? (ma61 clutch question) Mon, 26 April 2004 05:28 Go to previous messageGo to next message
never mind
person who installed the clutch pedal (not me) didn't put the bolt that attaches the pedal to the plunger thing in. which explains the lack of pressure - the "plunger" (vocab is lacking atm) was only getting pushed 1-2cm when the pedal was right to the floor.
will fix it and see what happens
YelloRolla
On your mum!
Re: is this normal? (ma61 clutch question) Mon, 26 April 2004 05:33 Go to previous messageGo to next message
draven wrote on Mon, 26 April 2004 15:28
never mind
Good idea, and smack the pedal installer up side of the head and (unless it's you) never let them forget how they let you down on this otherwise fine day.
Re: is this normal? (ma61 clutch question) Mon, 26 April 2004 05:56 Go to previous messageGo to next message
alright, that made things better
still almost no pressure, but there is some, which is what I was expecting - plus the slave cylinder (which I just installed) isn't leaking, a double bonus
Soarer
Wollongong
Re: is this normal? (ma61 clutch question) Mon, 26 April 2004 07:28 Go to previous messageGo to next message
Probably nothing wrong... same thing happened when I converted my car to manual. No pressure at all until I bled the clutch.
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: is this normal? (ma61 clutch question) Tue, 27 April 2004 08:59 Go to previous message
never mind
Sure, sure Greg...
Previous Topic:removing wiper arms from TA22 and hood lining
Next Topic:Remote brake booster problem.
Current Time: Wed Oct 21 02:57:44 UTC 2026
Total time taken to generate the page: 0.0045540332794189 seconds
