Classifieds » Parts Wanted » AW11 Speedometer problem
ptwong
AW11 Speedometer problem Mon, 26 April 2004 06:52 Go to next message
The speedometer not working in my AW11, i'm sure the speedo cable is workiong and someone told me it's the speed serson's problem. Does AW11 have speed serson?
and the charge me around $550 for fix it, it's the price ok?
they told me they can't find a secondhand speed serson.
is any have secondhand speed serson for AW11?
I feel very sad about this because i just bought this car and it's has problems coming for me ~~
Anyone can help~~~ Sad
ptwong50@yahoo.com.hk
._T_.
Re: AW11 Speedometer problem Mon, 26 April 2004 08:54 Go to previous messageGo to next message
aw11 uses a cable. late sw20 is electronic.
probably your cable is broken.
T
ptwong
Re: AW11 Speedometer problem Mon, 26 April 2004 09:32 Go to previous messageGo to next message
Hi friends, the cable i have just change it about 2 months and it's a new cable, bought from toyota Sad
My friend has take out the back of the cable and turn it.
when the cable is turning and the speedometer has move and shows the speed. After that, my friend sad the cable hasn't broken~~
What's going in my car~~is it really the cable's problem.
because i'm pretty sure AW11 should not have speed sersor
Any good suggestion for me??????
._T_.
Re: AW11 Speedometer problem Mon, 26 April 2004 22:32 Go to previous message
no speed sensor.
make sure the cable is correctly seated into the base on the gearbox - as that may be why it's not reading. check that the speedo worm gear is not broken by using a flat balded screwdriver & verify that you cannot turn the worm drive in the gearbox - not very difficult to remove this part from gearbox either - 10mm socket & screwdriver.
T
Previous Topic:TA22 parts
Next Topic:radiator and power steering pump to suit 1988 soarer mz21 7mgte
Current Time: Mon Nov 2 06:05:29 UTC 2026
Total time taken to generate the page: 0.027674913406372 seconds
