Toymods » Tech & Conversions » t50 gearbox problems
shindeokure
melbourne
t50 gearbox problems Mon, 26 April 2004 07:22 Go to next message
after letting someone test-drive my car without me being in it, i've noticed that it won't downshift into 2nd gear without alot of struggling. no crunching, just won't go in unless i shift 1/2 way towards 1st gear, then down.
any ideas on what the problem could be? it was working fine beforehand..
biohazard TA22
Re: t50 gearbox problems Mon, 26 April 2004 07:28 Go to previous messageGo to next message
I had a similar problem once before and it turned out the four bolts that hold the shifter to the box had come loose and there were only two holding it in, and they were about to pop out too. If it is that a phillips head screwdriver will sort it, if not, ummmm.....
shindeokure
melbourne
Re: t50 gearbox problems Mon, 26 April 2004 07:42 Go to previous messageGo to next message
i already inspected the shifter, and made sure it was all in properly. would it help if i adjusted the 2 spring things on each side?
mumblezzz
Gold Coast
Re: t50 gearbox problems Mon, 26 April 2004 09:05 Go to previous messageGo to next message
Funny you should mention this as I have the exact same problem.
It started happening after a lot of thrashing and a BIG mis-shift.
I would like to know if theres any way to fix it?
FKN16V
NSW, East Coast
Re: t50 gearbox problems Mon, 26 April 2004 10:47 Go to previous messageGo to next message
Im thinking that the 2nd gear syncro is on the way out, someone has been trying to spin wheels/wheels in 2nd gear.
Could also be that 2nd gear syncro is worn/on the way out and if its been driven hard the clutch isnt engaging enough to allow you too shift properly. Hows the freeplay on the clutch pedal.
Just a thought.
Steve
shindeokure
melbourne
Re: t50 gearbox problems Mon, 26 April 2004 11:05 Go to previous messageGo to next message
if the syncros are worn, wouldn't they crunch? mine doesn't engage at all.
how much are toyota syncros these days anyway?
ae86drift
sydney.au
Re: t50 gearbox problems Mon, 26 April 2004 11:10 Go to previous messageGo to next message
maybe slave cylinder?
i know my slave and master are both fucked.. royal
and mine does this all the time hehehe
FKN16V
NSW, East Coast
Re: t50 gearbox problems Mon, 26 April 2004 11:33 Go to previous messageGo to next message
From memory new syncros are around 60bucks each.
Does the clutch feel spongey
shindeokure
melbourne
Re: t50 gearbox problems Mon, 26 April 2004 12:00 Go to previous messageGo to next message
nope.. clutch is fine.
i might bleed it out just in case though.
fangsport
timaru NZ
Re: t50 gearbox problems Mon, 26 April 2004 12:50 Go to previous messageGo to next message
syncro's worn or broken detent spring/clip.
is the box noisy at idle with the clutch out? if so the input bearings are also worn.
shindeokure
melbourne
Re: t50 gearbox problems Mon, 26 April 2004 13:05 Go to previous messageGo to next message
theres a very faint whining noise.. but only with the shifter off. i'm guessing thats normal.
detent clip? is that the thing that sits on the thrust bearing?
Les
Re: t50 gearbox problems Tue, 27 April 2004 01:10 Go to previous message
hi - where do you get the syncros from ? Toyota ?
Previous Topic:Working out optimal track width
Next Topic:intercoolers????
Current Time: Fri Oct 16 15:32:37 UTC 2026
Total time taken to generate the page: 0.012778043746948 seconds
