Toymods » Tech & Conversions » Rubber mount on 2 peice tailshaft
Siktoy ra23
Plumpton/sydney
Rubber mount on 2 peice tailshaft Mon, 26 April 2004 10:11 Go to next message
I have a small problem with my tailshaft(it vibrates) the rubber mount has gone soft and I was hoping one of you guys would know how to fix it and if you can still get a new rubber for it
BEN
Re: Rubber mount on 2 peice tailshaft Mon, 26 April 2004 10:12 Go to previous messageGo to next message
If you're talking about the centre bearing, I hope you have deep pockets, cos they ain't cheap Smile
Try and find a replacement one in good condition Razz
Siktoy ra23
Plumpton/sydney
Re: Rubber mount on 2 peice tailshaft Mon, 26 April 2004 10:26 Go to previous messageGo to next message
yeah I have there is no such thing as a good replacment
Re: Rubber mount on 2 peice tailshaft Mon, 26 April 2004 10:28 Go to previous messageGo to next message
Well, I can't say for certain if Toyota stocks them for your car, but they are nearly $400 trade for an MA61 one if thats any indication.
Siktoy ra23
Plumpton/sydney
Re: Rubber mount on 2 peice tailshaft Mon, 26 April 2004 10:36 Go to previous messageGo to next message
WHOLY FARRRRRRRRRRRRRRRRRRRRKKKKKK
[Updated on: Mon, 26 April 2004 11:57]
Re: Rubber mount on 2 peice tailshaft Mon, 26 April 2004 11:02 Go to previous messageGo to next message
get it rebuilt?
or off to the wreckers we go...
Siktoy ra23
Plumpton/sydney
Re: Rubber mount on 2 peice tailshaft Mon, 26 April 2004 11:55 Go to previous messageGo to next message
can't I just pack somthing around the rubber to make it stiffer???
Re: Rubber mount on 2 peice tailshaft Mon, 26 April 2004 12:30 Go to previous messageGo to next message
What car is it?
Siktoy ra23
Plumpton/sydney
Re: Rubber mount on 2 peice tailshaft Mon, 26 April 2004 12:44 Go to previous messageGo to next message
its a ra23 with a hilux diff
Grega
melbourne.victoria.austra...
Re: Rubber mount on 2 peice tailshaft Mon, 26 April 2004 20:12 Go to previous messageGo to next message
for $400 it would be cheaper to get a single piece custom shaft MADE UP!
QIK 3SGTE
Re: Rubber mount on 2 peice tailshaft Mon, 26 April 2004 22:17 Go to previous messageGo to next message
I have a 2 piece tailshaft for sale if you want it. I am located in Sydney, at Stanmore.
celicaboy
Re: Rubber mount on 2 peice tailshaft Tue, 27 April 2004 10:32 Go to previous messageGo to next message
get it revolcanised however ya spell it
i cant see them being 400 though.. my old ra23 got it replaced i dont think it was to much but that was years ago repco should be able to get one in
Re: Rubber mount on 2 peice tailshaft Wed, 28 April 2004 00:29 Go to previous messageGo to next message
celicaboy wrote on Tue, 27 April 2004 18:32
Probably not $400, it's just Repco don't have one for a Supra.
CrAiGzEE
south of the big smoke
Re: Rubber mount on 2 peice tailshaft Wed, 28 April 2004 00:30 Go to previous messageGo to next message
siktoy when ya put the hilux diff in did you just get the second part of the teil shaft shortened?
how much that cost?
im planning on using the single piece from my ta23, as the 2 piece one wasnt made for high power applications. if i were u id do the same
Siktoy ra23
Plumpton/sydney
Re: Rubber mount on 2 peice tailshaft Wed, 28 April 2004 12:20 Go to previous messageGo to next message
I was advised to use the 2 peice shaft instead of a single and the rear half was shortened 20mm this cost me $175 including balancing, then I fucked the rubber putting it in oops.
The two peice held up ok at 7000rpm launches at the track and every were else I drive for that matter Evil or Very Mad
Siktoy ra23
Plumpton/sydney
Re: Rubber mount on 2 peice tailshaft Fri, 30 April 2004 07:59 Go to previous messageGo to next message
Rang around to try and find a new ruber mount today
rang repco No No No
rang peps No No No
rang toyota No No No
It seems that the are goooone
7M-Brisbane
Re: Rubber mount on 2 peice tailshaft Fri, 30 April 2004 08:25 Go to previous messageGo to next message
A straight piece of pipe does the trick Very Happy
Considerably so, I have had one made for each of my engine conversions (4 so far) made and the most expensive one was $140 including balancing.
Siktoy ra23
Plumpton/sydney
Re: Rubber mount on 2 peice tailshaft Fri, 30 April 2004 10:06 Go to previous messageGo to next message
it cost me $175 just to have mine shortened and a new one will cost me about $800
QIK 3SGTE
Re: Rubber mount on 2 peice tailshaft Fri, 30 April 2004 12:41 Go to previous messageGo to next message
dude i have a 2 piece tailshaft in good condition. $20, come and get it, I am at Stanmore
Jayem
Finland
Re: Rubber mount on 2 peice tailshaft Fri, 30 April 2004 13:26 Go to previous messageGo to next message
You can get cheap rubber mounts for MB's, (euro)Ford's and Volvo's to name few. And these really cost next to nothing in your local car parts store. Then get suitable bearing that fits to your tail shaft and rubber mount. The reason that Toyota centre bearing is so dear is that it's one piece unit. MB's Ford's and Volvo's have separate bearing, rubber mount and assy.
Fattony
Re: Rubber mount on 2 peice tailshaft Fri, 30 April 2004 15:25 Go to previous message
Hold on here u can get a new centre bearing for your car, i have one on my 2 peice tailshaft. When i converted the arse end to borg warner i had the back peice shortened and a new universal joint suited to the borg warner welded on. New universals in the front section near the box, and the mid shaft was replaced with a toyota dyna unit. This is as strong as you would be able to make the 2 peice shaft with balancing and a new bearing it cost just under $600. However the place who modded my drive shaft sourced the centre bearing, so try the place who shortend your rear section and see wat they come up with. I found i had to stick with the 2 peice becuase of the way my exhaust x over under the rear section of the shaft, so although it might have been pricy i doubt all the other work i done would have been a total of under 200 so i would say the centre bearings are more like 150-200 for a 23 new.
Previous Topic:URGENT: info/dimensions of 1jz flywheel/flexplate!
Next Topic:Tacho
Current Time: Wed Nov 18 17:29:31 UTC 2026
Total time taken to generate the page: 0.01840877532959 seconds
