Toymods » Tech & Conversions » 2T Piston Identification
dcleyne
2T Piston Identification Mon, 26 April 2004 10:39 Go to next message
Hi Folks,
I'm rebuilding my 2T at the moment and I'm looking for some help in figuring out what Pistons are being used in the motor. I did notice there is a number moulded on the side of the piston. I'm wondering if anyone can tell me what this number means...
http://members.optusnet.com.au/~danielcleyne/Celica/PistonIdentification.jpg
I have 2 that say 55 and 2 that say 75. Also, I have another one from a different motor that says 35. My immediate thoughts were that they were a size and that the 55 and 75 were oversized. I measured one of them with verniers but it didn't seem to be over the 85mm diameter.
Also, I noticed a couple of numbers stamped into the crown. The pistons I have range from 2 - 4 and from B - D. What do these numbers/letters mean? My workshop manuals have no info on these codes at all.
http://members.optusnet.com.au/~danielcleyne/Celica/PistonCrown.JPG
Any help would be appreciated.
Dan
dcleyne
Re: 2T Piston Identification Mon, 26 April 2004 22:39 Go to previous messageGo to next message
Just talked to an Engine reconditioner and his suggestion was that the numbers were just production identification marks.
Does anyone have any examples of what identification marks an oversized piston carries?
Dan
RWDboy
Re: 2T Piston Identification Mon, 26 April 2004 23:17 Go to previous messageGo to next message
Usually it's just on top of the crown of the piston...a number like 40 or 20 or whatever? I don't have any examples on me atm though.
SeptemberSquallIndustries
Re: 2T Piston Identification Tue, 27 April 2004 05:43 Go to previous messageGo to next message
Bump for subscribe, interested too.
wombat
Laverton, Vic
Re: 2T Piston Identification Wed, 28 April 2004 13:35 Go to previous messageGo to next message
This is correct.
The identafacation are numbers are
.25 = 10 thou
.5 = 20 thou
.75 = 30 thou
1.0 = 40 thou
dcleyne
Re: 2T Piston Identification Thu, 29 April 2004 01:25 Go to previous messageGo to next message
Thanks Wombat
I'm convinced now that my pistons are standard size which is a relief considering I ordered a set of rings before checking. That'll learn me Confused
Dan
SRacin
Christchurch, New Zealand
Re: 2T Piston Identification Thu, 29 April 2004 01:44 Go to previous messageGo to next message
in reference to the 1,2,3,4 numbers,
Just from observation these numbers will be stamped all over the motor, on the deck of the block beside each cylinder for example, and the rods, on the mains and big end caps etc.
Anyway as far as I know this is some form of factory tolerance number, however I could be wrong, just what im led to believe...
Im not sure but i think 1 is best and 4 is worst...
Anyone please feel free to step in and correct me Smile
Logan
dcleyne
Re: 2T Piston Identification Thu, 29 April 2004 13:18 Go to previous messageGo to next message
I saw something like this in a document about the 4AGE. Is this a manufacturing tolerance/clearance thing?
I also discovered that the rings I got are too thick. Sad
I have 2 sets of pistons. The motor I'm currently rebuilding has pistons with ~1.5mm thick compression rings and 4mm oil ring. The 'spare' motor's pistons have 2mm thick compression rings with the 4mm oil ring.
It boggles the mind as to why something like that would be. I can only assume that the piston changed over time during the car's manufacture period (later 2Ts had thicker rings for example) or one of the sets of the pistons are aftermarket.
If anyone has any info on this I'd be keen to know.
Dan
dcleyne
Re: 2T Piston Identification Fri, 30 April 2004 05:24 Go to previous message
Turns out the piston is aftermarket (of course) and given the lack of popularity of this product they don't make off-size rings for this motor any more.
So now I'm getting the piston ring grooves re-machined to the larger size. More money spent I didn't have in the first place Confused
Dan
Previous Topic:ae86 info.
Next Topic:T50 gearbox from T18 -> AE86
Current Time: Wed Nov 18 13:46:15 UTC 2026
Total time taken to generate the page: 0.0055088996887207 seconds
