Toymods » Tech & Conversions » will a rear sway bar help axle tramp
Mr DOHC
will a rear sway bar help axle tramp Mon, 26 April 2004 10:42 Go to next message
i have the opportunity ATM to buy a rear sway bar for my car, would that help settle the car down, i have leafs in the rear
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: will a rear sway bar help axle tramp Mon, 26 April 2004 10:47 Go to previous messageGo to next message
how long is a piece of string?
axle tramp is caused by a few different things,
Worn bushes
Worn Rear shocks
Un even lengths of trailing arms
etc, But the rear anti roll bar will stiff it up, however it may even make the tramp WORST. I'd get it,install it and look at the other problem areas if it is still bad.
PS: Leaves always tend to tramp more then spring rear ends due to their design
Mr DOHC
Re: will a rear sway bar help axle tramp Mon, 26 April 2004 11:03 Go to previous messageGo to next message
i'm just sick of not being able to launch it properly, i'm about to get my head done so i'll actually have power and i will still have to baby it off the line, would it be a wasted investment
RWDboy
Re: will a rear sway bar help axle tramp Mon, 26 April 2004 23:16 Go to previous messageGo to next message
A rear sway bar is always handy to have if you don't already have one!
gold28
Madrid - Spain
Re: will a rear sway bar help axle tramp Tue, 27 April 2004 00:14 Go to previous messageGo to next message
No it won't help tramp
There are a few ways of preventing axle tramp on leaf sprung cars but the first step is always making sure your existing components are all good as per simons post.
The sway bar might make a good addition to you handling. I would consider looking at a pan-hard rod or watts link as well to remove the boat type feel that leaf sprung rear ends have.
shinybluesteel
melbourne
Re: will a rear sway bar help axle tramp Tue, 27 April 2004 00:22 Go to previous messageGo to next message
try fitting some control links to stop the twisting of the banjo, this is the problem with leaf springs, they only react to wheel torque (if you want to call it that) by twisting and binding up, unlike a sprinter for example, which have solid links to stop this twist, and coil springs to do the springing. look up some oldschool drag racing stuff for ideas.
moo4AGZETA22
Tasmania
Re: will a rear sway bar help axle tramp Tue, 27 April 2004 01:35 Go to previous messageGo to next message
Go some slapper bars. They will fix most of your problem. You might also want to check the diff pinion angle. If this is out, then the car will tramp more.
The only BIG problem with slapper bars is the decrease in ground clearance.
Justin
Re: will a rear sway bar help axle tramp Tue, 27 April 2004 02:06 Go to previous messageGo to next message
AND they completely root your handling AND they're illegal on the street. Fine for dedicated drag cars but that's about it...
gold28
Madrid - Spain
Re: will a rear sway bar help axle tramp Tue, 27 April 2004 03:05 Go to previous messageGo to next message
Yep look at your existing suspension components first before doing something silly like tramp bars. I guess by the 18rg, it's not a dedicated drag car, so tramp bars are definitly something you don't want.
Look at your suspension bushes and shocks first.
Re: will a rear sway bar help axle tramp Tue, 27 April 2004 04:32 Go to previous messageGo to next message
IMHO a sawybar will not help tramp.. if only one side is tramping, it will upset the other side.
tramp occurs either becuase the shocks and springs are not controlling the wheel movement, or because the spring is winding up and suddenly releasing (which is a vicious circle)
if they are stock leaves, consider putting an extra leaf in, or possible a leaf just for the front half... stiffer springs and shocks in mine have removed tramp, and just havign a stiff front half will decrease wind up without the hassle of slapper bars (which are an archaic device).
rear sway bar will make the rear stay flatter as it transfers wheel movement from one side to the other.. but if the body is rolling, this may cause inside wheel to lift more and give more oversteer, and less traction with open diff?
or is it the other way around Razz Very Happy
Mr DOHC
Re: will a rear sway bar help axle tramp Tue, 27 April 2004 08:32 Go to previous messageGo to next message
gold28 wrote on Tue, 27 April 2004 13:05
whats that supposed to mean Razz
i can get some konis for like $220 a pair {vk's are a direct bolt in}, should i go for that,
how much would a watts/panhard rod setup be to install
celicaboy
Re: will a rear sway bar help axle tramp Tue, 27 April 2004 10:12 Go to previous messageGo to next message
if ya axle is tramping it will most likely be your shackle bushes flogged out and or rear leafs are all over the place
gold28
Madrid - Spain
Re: will a rear sway bar help axle tramp Tue, 27 April 2004 21:32 Go to previous messageGo to next message
Give your car the bounce test before racing out and buying more shocks. If they aren't too bad, I would have a close look at your bushes.
If your handy with a welder, or know someone that is, get a pan-hard rod or wats link from the wreckers and make up the mounts for them. You should get away with it for under $100.
alwaysRA23
Re: will a rear sway bar help axle tramp Wed, 28 April 2004 05:33 Go to previous messageGo to next message
no expert on leaf springs but when my mate threw a rear swaybar in his 18rg powered RA23, it was unsafe to drive in the wet, due to the car constantly spinning 180 degrees around corners.
and that was just normal everyday driving.. not ITS RAINING LETS GO DRIFTO!
Re: will a rear sway bar help axle tramp Wed, 28 April 2004 05:48 Go to previous messageGo to next message
This is what happens when your rear suspension is way too stiff. You can't just throw any old swaybar on and expect the handling to be better!
gold28
Madrid - Spain
Re: will a rear sway bar help axle tramp Wed, 28 April 2004 06:13 Go to previous messageGo to next message
Ohhh now come on Norbie, it may have just been a case of the engine being too powerful for the car. Fully.
alwaysRA23
Re: will a rear sway bar help axle tramp Wed, 28 April 2004 06:21 Go to previous messageGo to next message
you try to help someone out with telling them about a past experience and you get shot to shit,
Rolling Eyes
T O Y M O D S !
gold28
Madrid - Spain
Re: will a rear sway bar help axle tramp Wed, 28 April 2004 07:06 Go to previous messageGo to next message
Sorry, no offence intended there. It's more me having a go at the "drifters" that brag about their power and their full sik handling.
If the rear anti-roll bar is too big, you will get too much weight transfer on the back wheels and thus oversteer. Simple as that. Thats why you don't just buy a big rear bar and whack it on a standard car. Unless you want a car with ridiculous handling traits.
The anti-roll bar does not provide any rotational restraint about the axle line, nor does it provide any vertical restraint. Therefore it will have no effect on tramp. A bigger anti-roll bar will however increase power on oversteer which may manifest itself as tramp but that is secondary.
So to answer your original question
No
And it may actually make things worse.
Re: will a rear sway bar help axle tramp Wed, 28 April 2004 07:24 Go to previous messageGo to next message
my rear leaves ARE too stiff, and i DO get too much weight transfer.. sucks with open diff, and is horrible in the wet..
i have a 22mm front bar but transverse leaf Wink ewwwww
stiff rear, front biased weight, and 700kg car weight = slippery.
car is not too overpowered (105Nm) i think.... just shit suspension Very Happy
RWDboy
Re: will a rear sway bar help axle tramp Wed, 28 April 2004 07:31 Go to previous messageGo to next message
q Mr DOHC: Is your car lowered with softish springs? That may contribute to axle tramp. Hitting bump rubbers not good and also can cause your handling to suxor.
Mr DOHC
Re: will a rear sway bar help axle tramp Wed, 28 April 2004 07:57 Go to previous message
my suspension is STOCK, cept for konis in the front
the swaybar is the correct one that XXXXXXX suspension company brought out 25 years ago for my car, maybe i'll get some new rubbers,
if i do that and then get my springs reset at a later date, will they have to destroy the rubbers and get new ones
Previous Topic:Where to get 2TG head gaskets cheap?
Next Topic:71-72 celica rear bumper
Current Time: Fri Oct 23 19:21:02 UTC 2026
Total time taken to generate the page: 0.0066349506378174 seconds
