Toymods » Tech & Conversions » Ra60 struts into ta22
stylez
Ra60 struts into ta22 Tue, 27 April 2004 08:10 Go to next message
hello, i bought some shortened ra60 brakes/struts as a quick upgrade for my ta22, but when installing i found the bolt spacing on the steering knuckle arm (where the bottom of the strut joins on), the spacing on the ta22 arm is 85mm while the ra60 seems to be 90mm,
is this right? and does anyone know what arms i need to use?
i was hoping i could just pick up some ra60 arms ?
Rowan
torque
UK at moment
Re: Ra60 struts into ta22 Tue, 27 April 2004 10:24 Go to previous messageGo to next message
I had to get custom arms made up - although it didn't cost all that much (liek $40 each).. then get some adjustable camber pins at the same time (that attach the arm to the cross member) to get a decent alignment..
stylez
Re: Ra60 struts into ta22 Wed, 28 April 2004 03:47 Go to previous messageGo to next message
anyone else have experience with this ?
Re: Ra60 struts into ta22 Wed, 28 April 2004 04:44 Go to previous messageGo to next message
Longer arms are going to give you other problems, such as wheel clearance. On top of this you'll find the RA60 struts are too long for a TA22. I avoided all of this by installing the RA60 hubs/rotors/calipers on an RA23 strut; this involves a bit of metal fabrication work but at least you don't screw around with the suspension geometry.
All the info you need is here:
http://www.norbie.net/BrakeMods.htm
biohazard TA22
Re: Ra60 struts into ta22 Wed, 28 April 2004 04:47 Go to previous messageGo to next message
I am about to install some RA65 struts into my TA22, apparently the RA65 knucle arm fits. It should bolt straight up to the strut.
stylez
Re: Ra60 struts into ta22 Wed, 28 April 2004 06:24 Go to previous message
theyve been shortened norbie, so it should be ok, ill have to head out to the wreckers on the weekend with my tape measure i guess.
Previous Topic:dropping an ma61 radiator 5mm
Next Topic:Considering Manual Swap, need advice!
Current Time: Fri Oct 23 15:18:12 UTC 2026
Total time taken to generate the page: 0.0051121711730957 seconds
