Toymods » Tech & Conversions » Bleeding the clutch on a GT4
Puffy
Bleeding the clutch on a GT4 Tue, 27 April 2004 11:53 Go to next message
Is this no different then bleeding brakes? I have installed the clutch cylinder on my GT4 and have bleed it but it still feels spongy.
I have had someone pump the clutch and hold the pedal down then I have undone the bleeding screw slightly and as soon as I get some fluid out of it I tighten it back up and repeat the process. I did this about 8 times, is that enough ?
Am I doing anything wrong or is there a better way to do this.
Thanks,
camryGT?
Re: Bleeding the clutch on a GT4 Tue, 27 April 2004 12:32 Go to previous messageGo to next message
Just did the master and slave clutch cylinders on my sv21 camry a few weeks ago, they would be similar thou.
I found if you undo the bleeder valve thing first, then get someone to push the clutch all the way to the floor and hold it there. Then do the bleeder valve up fairly tight and then get the person to let the clutch up again.
I did this about 5 times and the clutch felt great, no air in it at all.
Make sure they don't let the clutch pedal up at all with the valve undone, as you will just get more air in it.
Some people like the idea of a bleeder bottle. its just a bottle with some fluid in it and a short pipe attached to the end of the valve, just pump the pedal up and down a few times and the air will usually get forced out. This is good if you are on your own, but if the air bubble is a long way up the pipe it may not escape.
The first way should always work
Works for the brakes to.
Puffy
Re: Bleeding the clutch on a GT4 Thu, 29 April 2004 06:49 Go to previous message
thanks for the advise, I will give it a go.
Previous Topic:Hills Motorsport?????
Next Topic:RA60 Wheel Widths + Offset (Supra 14x7"??)
Current Time: Sat Nov 21 00:13:01 UTC 2026
Total time taken to generate the page: 0.0048511028289795 seconds
