Toymods » Members Rides » Simon's Drift AE86
Simon-AE86
Banned user
ADELAIDE - The Drift City
Simon's Drift AE86 Tue, 27 April 2004 12:06 Go to next message
Specifications
Car: 1983 Toyota Sprinter, Australian delivered Levin
Engine: 4age Smallport 100kw Engine from AE92 twin cam Corolla. Internally standard. Converted to RWD, Modified intake manifold, Loom + ECU from Bigport AE86 motor. 4-2-1 Extractors running long primaries, 2.26 inch exhaust system over the diff. Performance lead and coil kit. K&N Air filter with custom cold air box.
Drivetrain: Extreme H/D Clutch, Stock T-50 Gear box, T-18 diff housing with TA22 Celica 4.1 diff ratio, New bearings and fitted with a brand new TRD 2 way LSD.
Brakes
Stock (for now!!)
Wheels:
Buddy Club P1 Racing Wheels 15X7, 3.7 Kg per rim
SSR Reverse Mesh 15X7
Advan Oni’s 15X7
Suspension: Front:
AE86 Struts modified to Short Stroke specs and fitted with Coilover Height Adjustment, GAB 4 way adjustable short stroke shock. 10 kg/mm 200mm Tein Spring, 20mm helper spring, HKS Adjustable Uppers, Cusco Strut Brace, Modified castor rod, Mitsubishi Sigma Lower Control Arms, RA40 Celica Tie rods, Standard anti-roll bar, Power steering arms (shorter then non P/S) from Jap AE86. 40mm Roll Center Adjusters, 5mm wheel spacer
Rear:
Cusco 6kg/mm 240mm free-height spring, spring rubbers removed, TRD/KYB 8 way adjustable short stroke shock absorbers fitted with hard utherane bushes. Modified factory panhard rod, Adjustable lower trailing arms to adjust pinion angle. Longer wheel studs from Mitsubishi Sigma fitted, 5mm wheel spacer. Cusco 4 point Roll Cage, Cusco Adjustable Rear Strut brace.
Interior: Heater core, fan, air cond, glovebox, consol surround, rear seat, entire rear trimmings and carpet all removed from car. Door trims replaced with sheet aluminum as is rear hatch and rear quarters. Drivers seat is Sparco fixed back bucket race seat, Passenger seat is stock. Nardi steering wheel with boss kit and removable boss unit also fitted for extra length. 3 Stage shiftlight fitted to dash.
Exterior: Panda bumpers, Toyota White number 3 with Jet black on bonnet. Modified front bumper wheel arch to clear Wheel due to excessive track and castor, Rolled guards, Sticker work courtesy of Sponsors.
Settings:
Front Camber: 4 degrees Negative
Front Track: 1610mm
Front Castor: 7 degrees positive
Front Toe: 2mm toe out
Rear Track 1550mm
Rear Pinion Angle: TBA
Special Thanks to the following:
Japanese Motor Sports www.japanesemotorsport.com.au 2 Rosberg Road, Wingfield, Adelaide, South Australia, 5013
Phone +618 8260 6919 Fax +618 8260 5000
A-Spec Performance and Tuning
Ph: 0418 999 346 - Steve Grant
HMS Automotive - www.AE86world.com
3/17 Veronica Street, Capalaba, QLD 4157
ph: Fax (07) 3823 2525 Fax (07) 3823 2525
JDM Yard www.jdmyard.com
http://users.chariot.net.au/~simon86/PICT0076.jpg
http://users.chariot.net.au/~simon86/drifto006.jpg
http://users.chariot.net.au/~simon86/DSCF0056.JPG
[Updated on: Tue, 27 April 2004 12:18]
ae95
Re: Simon's Drift AE86 Tue, 27 April 2004 14:45 Go to previous messageGo to next message
Very Nice, got any pics of the coilovers?
-ian
sated
Re: Simon's Drift AE86 Tue, 27 April 2004 16:39 Go to previous messageGo to next message
Heya Simon,
Very nice dood, very nice indeed.
Take it easy fella.
James
Skaney
Re: Simon's Drift AE86 Wed, 28 April 2004 00:38 Go to previous messageGo to next message
Hey simon where did you get the RCA's from?
Simon-AE86
Banned user
Re: Simon's Drift AE86 Wed, 28 April 2004 07:25 Go to previous messageGo to next message
made em.
If you want some JMS have some for sale.
nb86
melbourne
    sadff
Re: Simon's Drift AE86 Wed, 28 April 2004 08:26 Go to previous messageGo to next message
looks wicked. btw the springs arrived and theyre perfect, thanks dude. its funny, ive ended up with an almost replica of your car, without knowing it. suspension, white w/panda bumpers, black bonnet [mine is frp hehe.] except im running twin carbs and a few other engine tweaks.
Simon-AE86
Banned user
Re: Simon's Drift AE86 Wed, 28 April 2004 09:16 Go to previous messageGo to next message
haha really?
thats sweet mate, You runing carbs on the 4age?
Simon
ae86drift
sydney.au
Re: Simon's Drift AE86 Wed, 28 April 2004 09:33 Go to previous messageGo to next message
Front Track: 1610mm
Rear Track 1550mm
how did you adjust track ? wider wheels?
castor and toe?
Aust162
Melb, Victoria
Re: Simon's Drift AE86 Wed, 28 April 2004 09:45 Go to previous messageGo to next message
definately looks like a drifting car Very Happy sweet ride dude.
Simon-AE86
Banned user
Re: Simon's Drift AE86 Wed, 28 April 2004 10:59 Go to previous messageGo to next message
dare ya to read everything i wrote above there garth Wink
then if u still dont know ask me and i will tell ya Wink
ae86drift
sydney.au
Re: Simon's Drift AE86 Wed, 28 April 2004 11:08 Go to previous messageGo to next message
Quote:
HKS Adjustable Uppers, Modified castor rod, Mitsubishi Sigma Lower Control Arms, RA40 Celica Tie rods, Power steering arms (shorter then non P/S) from Jap AE86. 5mm wheel spacer
i know that you have done these mods and they will acheive the specs you listed, but what does what EXACTLY?
Smile
Simon-AE86
Banned user
Re: Simon's Drift AE86 Wed, 28 April 2004 11:30 Go to previous messageGo to next message
sigma arms increase track and camber
RA40 celica tie rods allow you to retain thread on your rack ends when you pump out the track
camber tops fine tune camber also
Razz
Re: Simon's Drift AE86 Wed, 28 April 2004 12:13 Go to previous messageGo to next message
Very nice indeed! The specs are very impressive!
I saw you drive at the HPI drift event recently and u went off mate.
Can I ask about the GAB 4 way adjustable shocks? What car did they come from?
Joel
ae95
Re: Simon's Drift AE86 Wed, 28 April 2004 12:35 Go to previous messageGo to next message
Is it dodgy to run no spring rubbers ? Noisy?
Simon-AE86
Banned user
Re: Simon's Drift AE86 Wed, 28 April 2004 13:46 Go to previous messageGo to next message
cheers joel Very Happy
as for the spring rubbers,yes more noise will be transmitted, but no its not dodgy at all, just gives a better feel and one less thing to flex in the car
Simon
nb86
melbourne
    sadff
Re: Simon's Drift AE86 Sat, 01 May 2004 03:38 Go to previous messageGo to next message
someone queried about my carb setup. its unusual in aust but not overseas. basically i did it coz my engine specs are outside the factory ecu's mapping ability. if you fit them to a stock engine youll probly gain a coupla hp but not much and youll use more fuel, theyre really only useful for modified engines.the sound is insane though!
fub_
Re: Simon's Drift AE86 Mon, 03 May 2004 02:46 Go to previous messageGo to next message
i want sponsors, Ae86 setup for drift
and lots of money
sucks being young and doin HSC
Re: Simon's Drift AE86 Fri, 14 May 2004 02:05 Go to previous messageGo to next message
Is there any tricks I should be aware of before changing to sigma control arms? Like does the swaybar mount up and do you use toyota balljoint or mitsubishi?
Joel
ae86slideways
warrnambool VIC
Re: Simon's Drift AE86 Fri, 14 May 2004 13:40 Go to previous messageGo to next message
Hi Simon,were you at the Calder drift nats? I think i saw your car there.Do you know the guy who had the other white 86 with the quad throttle setup?
takai
Re: Simon's Drift AE86 Sat, 15 May 2004 11:20 Go to previous messageGo to next message
I think i know that car. But he would prefer to keep it quiet. You can find it though, by the sig.
Anyway, Simon, i was wondering if you had some interior shots, esp of the rear area.
Simon-AE86
Banned user
Re: Simon's Drift AE86 Mon, 17 May 2004 08:25 Go to previous messageGo to next message
no tricks to the sigma arms, u may need to shave off some of the bush tho, easy to do.
[AE86]
icon14.gif  Re: Simon's Drift AE86 Thu, 20 May 2004 18:16 Go to previous messageGo to next message
Saw you @ Drift Nats!.. You rock mate.. hehe
Very very nice car *BIG THUMBS UP*
Simon-AE86
Banned user
Re: Simon's Drift AE86 Sun, 23 May 2004 06:56 Go to previous messageGo to next message
cheers buddy Very Happy
william68
Re: Simon's Drift AE86 Sun, 23 May 2004 16:32 Go to previous messageGo to next message
Simon,
What offset if your wheels at the front end ?
I am having trouble clearing the wheel arch/fender.
Regards,
William
Simon-AE86
Banned user
Re: Simon's Drift AE86 Mon, 24 May 2004 12:58 Go to previous message
+12 and +4 front and rear
Previous Topic:rusted out ta22 (my baby)
Next Topic:Dodgy Haro's KE20 - Go the Yello Pokemon!
Current Time: Sun Oct 18 20:00:50 UTC 2026
Total time taken to generate the page: 0.007004976272583 seconds
