Toymods » Tech & Conversions » Help Needed No. 2 Fuel Pipe Flared Ends
ra23celica
Help Needed No. 2 Fuel Pipe Flared Ends Tue, 27 April 2004 15:43 Go to next message
Stupid question 2:
How do you create the 'bulge' that sits 5mm down from each end of the standard Toyota fuel and return pipes ? I have just fitted an 8mm pipe to my RA23 and am keen to get these bulges in place.
Thanks,
Mitch.
sideshow
Re: Help Needed No. 2 Fuel Pipe Flared Ends Tue, 27 April 2004 18:18 Go to previous messageGo to next message
buy a flaring tool
a prick of a job to do with lines in the car
or u could take lines to pirteck and get them done
ra23celica
Re: Help Needed No. 2 Fuel Pipe Flared Ends Wed, 28 April 2004 00:19 Go to previous messageGo to next message
Does a flaring tool only flare the end of the pipe, so you can sleeve another pipe inside it ?
I want to get that bulge 5mm down from the end of the pipe.
I'm really not keen to pull the lines out now that they are fitted, either way its a prick of a job.
Thanks for your ideas mate.
Mitch.
YelloRolla
On your mum!
Re: Help Needed No. 2 Fuel Pipe Flared Ends Wed, 28 April 2004 03:01 Go to previous messageGo to next message
With a proper double flaring tool you can bulge the pipe at the end (a single flare), not 5mm down the tube. It is not as neat as the Toyota set up, but it works well.
ra23celica
Re: Help Needed No. 2 Fuel Pipe Flared Ends Wed, 28 April 2004 07:10 Go to previous messageGo to next message
Another good idea - thanks Jason.
Mitch.
TD42T
Mildura
Re: Help Needed No. 2 Fuel Pipe Flared Ends Wed, 28 April 2004 10:39 Go to previous messageGo to next message
To do that you need a Crox tool.
I have a 1/2" one but not 8mm.
Marty
Fattony
Re: Help Needed No. 2 Fuel Pipe Flared Ends Thu, 29 April 2004 07:49 Go to previous message
You dont neccasary need to flare you fuel lines ends. You can buy fittings the have a clamp on and olive setup like a boost guage vac line. They have been tested to hold 250psi also. They are available through www.vpw.com.au
Previous Topic:ae86 bushings
Next Topic:Hills Motorsport?????
Current Time: Sat Nov 21 01:20:02 UTC 2026
Total time taken to generate the page: 0.005267858505249 seconds
