Toymods » Tech & Conversions » dropping an ma61 radiator 5mm
dropping an ma61 radiator 5mm Wed, 28 April 2004 05:04 Go to next message
right.
trial fitted the radiator and shroud properly today, after some power-tool assisted mods to the shroud.
there's now 1cm clearance between the fans and the water pump (not ideal, but no choice)
the problem is the radiator doesn't quite sit low enough. the 2 bolts that hold the rad in place are about 5mm too high - which is caused by the radiator being too high. the 2 supports seem to be the problem.
Is there any easy way of lowering these supports?
choices at the moment are:
1) bash them lower with a hammer (but I dont think this will be terribly effective)
2) grind a bit of them away (again, looking how they're designed, I dont think this will be terribly effective)
3) remove the supports, re-drill the holes for the supports 5mm higher, thus dropping them. this is the best option I can think of, but also rather time consuming (and I can tell is will be annoying)
can anyone offer any better suggestions, or something I may have overlooked that is causing the radiator to sit too high?
btw - rad is stock top and bottom tanks, triple cored
Re: dropping an ma61 radiator 5mm Wed, 28 April 2004 05:52 Go to previous messageGo to next message
I had a similar problem after I did my engine conversion; stock radiator, stock mounts, but the top mounting tabs didn't line up any more! It turns out the radiator support panel had been bent when I was lowering the engine in (this is very easy to do, it's not that strong), so after a bit of careful adjustment with a big fuck-off hammer it was all good. Smile
V8_MA61
Re: dropping an ma61 radiator 5mm Wed, 28 April 2004 05:57 Go to previous messageGo to next message
I had to drop the radiator mounts out completely for my new radiator Laughing . but, i made brackets that bolt the rad to the front of the chassis, and hold on my 2 fans.
[Updated on: Wed, 28 April 2004 05:58]
Re: dropping an ma61 radiator 5mm Wed, 28 April 2004 06:04 Go to previous messageGo to next message
so norbie - you reckon just bash the top support a bit?
I have a variety of large hammers lying around my car - the one I'm gonna use to get the bloody crank pulley on would do nicely for this job
Re: dropping an ma61 radiator 5mm Wed, 28 April 2004 06:26 Go to previous messageGo to next message
That's the approach I'd take, but as you know I'm a dodgy bastard. Smile
Re: dropping an ma61 radiator 5mm Wed, 28 April 2004 06:30 Go to previous message
hehe Smile
I'll see if it looks straight or not
that was something I hadn't actually thought of.
Previous Topic:71-72 celica rear bumper
Next Topic:Ra60 struts into ta22
Current Time: Fri Oct 23 16:50:17 UTC 2026
Total time taken to generate the page: 0.0059201717376709 seconds
